DANL5CMBAC0 REV C. 2 defective capacitors and I couldn't find what it was. Thank you.
  • ismailakyoltr
    • Mar 2015
    • 109
    • TURKEY
    Casper Excalibur G650.8750
    Model: NL5C-N17P
    DANL5CMBAC0 REV C
    It malfunctioned at the same place 1 month ago, I put it on randomly and it came again. I didn't want to remove it because the putty is of good quality.
  • ismailakyoltr
    • Mar 2015
    • 109
    • TURKEY
    Re: Hi. 2 defective capacitors and I couldn't find what it was. Thank you.
    last time i installed 10U/25V
    • ismailakyoltr
      • Mar 2015
      • 109
      • TURKEY
      Can be deleted thanks. Help came from another forum. 4.7uF / 25V
        • 21948
        Why delete it when the info youve given can help someone else reading this forum
        • rumpumpel1
          How do I find a defective RAM chip
          by rumpumpel1
          I have a ThinkPad T14 which always finds an error at a very specific address during a RAM test. I therefore believe that exactly one of the RAM chips on the mainboard is defective. How do I find this defective RAM chip?
          07-29-2025, 11:55 AM
        • greystash
          How do I find the correct capacitors?
          by greystash
          I recently recapped my first computer (Power Mac 6100) and it seemed to go ok. After trying to boot it I get a crackly boot chime and then I hear the crash sound.
          How do I know if the replacement capacitors are suitable? (I am a total newbie and should have done a bit more research obviously)
          Original capacitors labelled:
          Y4 (I believe this is the batch number?)
          47
          16V
          On my other 6100 they are labelled:
          Small rectangle and then "4E"
          47
          16V
          Replacement capacitors: (aluminum polymer solid-electrolyte...
          10-18-2022, 06:24 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
