HP 242 G1 6050A2593401-mb-a02
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    HP 242 G1
    6050A2593401-mb-a02
    thermal shutdown occured
    system temperature (90D)
    fan and heatsink already clean,thermal paste clean and re apply.
    any solution for this error?
    i cant find schematic or boardview for this model.
    i dont have any idea where is thermal circuit location.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 242 G1 6050A2593401-mb-a02
    Grab any inventec schematic with same kbc and proceed further.
    • Udemzy
      • May 2017
      • 164
      • Guatemala
      Do a clean me region first.
      • Veyron7887
        Laptop overheating after replacement thermal paste
        by Veyron7887
        Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
        11-24-2024, 05:08 AM
      • kacangpolo
        Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
        by kacangpolo
        I have problem with my laptop, with code board X415EA 2.0,
        laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
        I did :
        1. Flash Bios
        2. RTC_RST 3.3V
        3. LID_SW 3.3V
        4. WLAN_WAKE# 3.3V
        08-26-2025, 04:42 AM
      • cruiser_
        A1466 820-00165 intermittent shutdown
        by cruiser_
        hi there,
        Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
        Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
        Gives shutdown cause -128.
        Seem to work fine in SMC bypass.
        Same shutdown happens with disconnected TP/KB/KBLED/CAM.
        Observations:
        - SMC_RESET_L - when pulled down - plug goes orange/green and...
        10-11-2022, 12:06 PM
      • caspian
        Can thermal paste cause corrosion?
        by caspian
        Dear members,
        I have got an ordinary gray thermal paste that has no name/model on the box.
        I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
        I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
        Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
        Is it safe to leave the thermal paste on the pins?
        I guess the thermal paste...
        06-19-2020, 10:47 AM
      • digitaldisorder
        GIGABYTE G5 KF5 RC555 BIOS location
        by digitaldisorder
        Can someone please direct me to the location of the BIOS? I've attached an image of the motherboard. Would like someone to point out the location or if I do indeed need to pull the motherboard if it's on the other side. Thank you....
        08-14-2025, 03:51 PM
