HP 242 G1 6050A2593401-mb-a02
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    HP 242 G1
    6050A2593401-mb-a02
    thermal shutdown occured
    system temperature (90D)
    fan and heatsink already clean,thermal paste clean and re apply.
    any solution for this error?
    i cant find schematic or boardview for this model.
    i dont have any idea where is thermal circuit location.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 242 G1 6050A2593401-mb-a02
    Grab any inventec schematic with same kbc and proceed further.
    • Udemzy
      • May 2017
      • 151
      • Guatemala
      Do a clean me region first.
      • Veyron7887
        Laptop overheating after replacement thermal paste
        by Veyron7887
        Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
        11-24-2024, 05:08 AM
      • cruiser_
        A1466 820-00165 intermittent shutdown
        by cruiser_
        hi there,
        Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
        Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
        Gives shutdown cause -128.
        Seem to work fine in SMC bypass.
        Same shutdown happens with disconnected TP/KB/KBLED/CAM.
        Observations:
        - SMC_RESET_L - when pulled down - plug goes orange/green and...
        10-11-2022, 12:06 PM
      • caspian
        Can thermal paste cause corrosion?
        by caspian
        Dear members,
        I have got an ordinary gray thermal paste that has no name/model on the box.
        I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
        I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
        Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
        Is it safe to leave the thermal paste on the pins?
        I guess the thermal paste...
        06-19-2020, 10:47 AM
      • howardc64
        P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
        by howardc64
        History
        - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
        - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
        - Fixed 2 circa 2015 Vizios before with classical main board...
        11-28-2020, 04:25 PM
      • RATIM SIDDIQUE
        hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
        by RATIM SIDDIQUE
        automatic shutdown after 30 sec of display coming
        do not shutdown without ramstick
        someone give me idea plz
        08-20-2024, 03:50 AM
