Lenovo V110-15IAP It won't turn on, it won't charge
  • Jokerx84
    • Sep 2017
    • 52
    • Hungary
    Hi!
    Lenovo V110-15IAP (LV114A_MB 15270-1) It doesn't turn on, it doesn't charge, only the charging LED flashes orange!
    Does anyone know what the problem could be?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Lenovo V110-15IAP It won't turn on, it won't charge
    No we do not have a glass bol to see. Take hd pictures off the bord front and back , and do measurements from all grey coils and the current sensor, voltage and resistor mode at 200 ohms without power , cmos battery , wifi card , mrmory etc...
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Try with another charger, try without battery connected ...than do what stevedb ask for
      • Jokerx84
        • Sep 2017
        • 52
        • Hungary
        I measured this
        • mon2
          • Dec 2019
          • 14677
          You have 2 x DC-in mosfets on this logic board.
          Using the resistance mode, check the mosfet condition of each.
          Remove all power / no battery.
          Meter in resistance mode.
          Check the resistance across the mosfet pins to check if it is defective.
          Source (1-2-3) & Drain (5-6-7-8)
          Source (1-2-3) & Gate (4)
          Gate (4) & Drain (5-6-7-8)
          Post the above readings (and the meter scale) for PU4401 and then again for the next mosfet PU4402 that follows. A low reading = defective mosfet.
          reference reading (see the resistance table):
          http://electronicsbeliever.com/how-t...0good%20MOSFET.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Voltage on S-D-G pins of first 2 dc-in mosfets also.
            • Jokerx84
              • Sep 2017
              • 52
              • Hungary
              voltage on s-d-g pins of first 2 dc-in mosfets also.
              pu4401
              s=20.1v
              g=6.7v
              d=20.1v
              pu4402
              s=20.1v
              g=20.1v
              d=2.7v
              • mon2
                • Dec 2019
                • 14677
                Did you miss reading post #5 ?
                • Jokerx84
                  • Sep 2017
                  • 52
                  • Hungary
                  Sorry!
                  PU4401
                  PU4402
                  Source (1-2-3) & Drain (5-6-7-8)= 1.1Mohm
                  Source (1-2-3) & Gate (4)=1.1Mohm
                  Gate (4) & Drain (5-6-7-8)=1.2Mohm
                  • mon2
                    • Dec 2019
                    • 14677
                    The resistance readings are the same for BOTH mosfets ?
                    If yes, the mosfets are fine. Will review the voltages once at the office but the GATE voltage of PU4402 is a suspect.
                    • mon2
                      • Dec 2019
                      • 14677
                      PU4402 = battery mosfet so it is correct that PU4402 (P-channel) will remain OFF with the missing battery using the posted gate voltage. Gate has to be more negative than the SOURCE voltage to turn this mosfet ON.
                      Q: Do you have the battery installed on this unit ? Believe that you do not but there is a d=2.7v reading ?
                      Can you confirm this ?
                      Next, remove all power -> perform the same resistance checks on the battery charging mosfets @ PU4403 & PU4405. Post the resistance values & scale used on your meter.
                      • Jokerx84
                        • Sep 2017
                        • 52
                        • Hungary
                        sorry I didn't have time
                        • mon2
                          • Dec 2019
                          • 14677
                          Do you have the SAME resistance readings on both of the battery charging mosfets ?
                          To confirm again, if you remove the BATTERY - you still read ~2v7 on the battery connector?
                          • Jokerx84
                            • Sep 2017
                            • 52
                            • Hungary
                            yes
                            • mon2
                              • Dec 2019
                              • 14677
                              measure the voltage on S-D-G pins of the battery charge mosfets.
                              Are the voltages the same if the battery is removed? If the battery is installed?
                              • Jokerx84
                                • Sep 2017
                                • 52
                                • Hungary
                                same voltage with and without accumulator
                                pu4401
                                s=20.1v
                                g=6.7v
                                d=20.1v
                                pu4402
                                s=20.1v
                                g=20.1v
                                d=2.7v
                                • mon2
                                  • Dec 2019
                                  • 14677
                                  There are 2 more mosfets that are used to charge the battery.
                                  Can you post their voltages on each pin and the PQ label for each?
                                  Do not have the schematic at this time to check their location.
                                  • Jokerx84
                                    • Sep 2017
                                    • 52
                                    • Hungary
                                    SiS412DN PU4403 and PU4405
                                    PU4403
                                    S=2.7V
                                    D=20.3V
                                    G=2.7V
                                    PU4405
                                    S=0V
                                    D=0V
                                    G=2.7V
                                    • mon2
                                      • Dec 2019
                                      • 14677
                                      Remove all power. Check the resistance (PU4403 and PU4405) of these same mosfets as before.
                                      • Jokerx84
                                        • Sep 2017
                                        • 52
                                        • Hungary
                                        PU4403
                                        PU4405
                                        Forrás (1-2-3) & Lefolyó (5-6-7-8) = 1 Mohm
                                        Forrás (1-2-3) & Kapu (4) = 1 Mohm
                                        Kapu (4) & Lefolyó (5-6) -7-8) = 1 Mohm
                                        • acata
                                          Lenovo T470 Turn on and off in seconds while charge
                                          by acata
                                          Lenovo T470 turns on and off in seconds while charging. But it won't turn on without charging.
                                          The power supply generates 0.1A, turns on with the orange LED, the fan spins for 1 second, and off.
                                          It looks like the motherboard has some work previously on the CPU and another component. came to me also without cmos battery.
                                          I don't have boardview for further examination.
                                          Please kindly assist me to solve this problems..
                                          03-25-2025, 08:32 AM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • g1150
                                          Lenovo G565 Laptop , LCD not turn on, external terminak ok.
                                          by g1150
                                          Lenovo G565 Laptop onboard LCD Display does not turn on.
                                          Only works with external Monitor.
                                          I am trying to verify that the LCD signals from the motherboard are ok.
                                          The LCD was working, but over time happened to not turn on more frequently.
                                          Now dead.
                                          Possibly the cable from MB to LCD is broken somewhere.
                                          I just wonder how it is detected if external or internal monitor shall be activated ?
                                          I found the following schematic on the net:
                                          Problem 2:
                                          The graphics chip ATI Mobility Radeon HD5470 seems defective.
                                          On Win7...
                                          05-07-2025, 11:51 AM
                                        • melvinvdb
                                          Lenovo y520-15ikbm most of the time doesn't turn on
                                          by melvinvdb
                                          I've repaired a few laptops in my life but this time my own laptop died😂.
                                          Funny enough this one is a bit tough on me.
                                          It doesn't turn on (most of the time).
                                          Model: Lenovo y520-15ikbm (NM-391).
                                          The only way to make it turn on is:
                                          1) unplug battery + charger + rtc (seems irrelevant)
                                          2) wait a minute
                                          3) plug battery/charger in
                                          4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
                                          5) when it turns on it also displays POST...
                                          08-15-2024, 12:28 PM
                                        • Evgenii999
                                          Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
                                          by Evgenii999
                                          I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
                                          Symptoms:
                                          The laptop does not power on and does not respond to the power button.
                                          Background:
                                          According to the owner, her child was playing on the laptop when it suddenly shut down.
                                          What has been done so far:
                                          Original charger is missing; the non-original one was tested and found faulty (0 V output).
                                          Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
                                          10-25-2025, 06:07 AM
