Lenovo V110-15IAP It won't turn on, it won't charge
  • mon2
    • 14672
    Re: Lenovo V110-15IAP It won't turn on, it won't charge
    I think the resistance readings are not correct.
    What is the meter scale used for these measurements?
    If you read '1' or 'OL' on the meter then you must switch to a higher scale.
    Or is your meter auto ranging? Post a picture of the meter.
    Start with the lowest resistance scale on the meter and confirm again the resistance values. Each reading cannot be exactly 1 Mohm.
    • didje3
      • Jun 2021
      • Latvia
      Any solution for this, have exact the same problem with my lenovo?
      • acata
        Lenovo T470 Turn on and off in seconds while charge
        by acata
        Lenovo T470 turns on and off in seconds while charging. But it won't turn on without charging.
        The power supply generates 0.1A, turns on with the orange LED, the fan spins for 1 second, and off.
        It looks like the motherboard has some work previously on the CPU and another component. came to me also without cmos battery.
        I don't have boardview for further examination.
        Please kindly assist me to solve this problems..
        03-25-2025, 08:32 AM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • g1150
        Lenovo G565 Laptop , LCD not turn on, external terminak ok.
        by g1150
        Lenovo G565 Laptop onboard LCD Display does not turn on.
        Only works with external Monitor.
        I am trying to verify that the LCD signals from the motherboard are ok.
        The LCD was working, but over time happened to not turn on more frequently.
        Now dead.
        Possibly the cable from MB to LCD is broken somewhere.
        I just wonder how it is detected if external or internal monitor shall be activated ?
        I found the following schematic on the net:
        Problem 2:
        The graphics chip ATI Mobility Radeon HD5470 seems defective.
        On Win7...
        05-07-2025, 11:51 AM
      • melvinvdb
        Lenovo y520-15ikbm most of the time doesn't turn on
        by melvinvdb
        I've repaired a few laptops in my life but this time my own laptop died😂.
        Funny enough this one is a bit tough on me.
        It doesn't turn on (most of the time).
        Model: Lenovo y520-15ikbm (NM-391).
        The only way to make it turn on is:
        1) unplug battery + charger + rtc (seems irrelevant)
        2) wait a minute
        3) plug battery/charger in
        4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
        5) when it turns on it also displays POST...
        08-15-2024, 12:28 PM
      • Evgenii999
        Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
        by Evgenii999
        I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
        Symptoms:
        The laptop does not power on and does not respond to the power button.
        Background:
        According to the owner, her child was playing on the laptop when it suddenly shut down.
        What has been done so far:
        Original charger is missing; the non-original one was tested and found faulty (0 V output).
        Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
        10-25-2025, 06:07 AM
