Macbook Pro 2010 Not Charging
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi guys i have an A1278 Macbook Pro 2010 820-2879 that doesn't charge the battery.It can run of a battery.I tried almost everything i know. But PPBUS_G3H just keeps reading 12.21V
    Things i tried are as follows: I have another identical Board that gives 12.56v on PPBUS_G3H only thing is it has a bad GPU it seems. So i took most of the parts from it and slapped it onto this good board am working on presently... but it's PPBUS_G3H stays at 12.21v. Have 3x known good batteries. I swapped the SMC.I also swapped the ISL.Tried 2 ''new'' ISL on it.I swapped Q7030 and Q7035 at the same time i tried the new ISL's.Changed R7051 R7052,C7025,R7005,R5087
    PPBUS_G3H = 12.21v
    SMC_Reset_L = 3.3V
    R5280 + R5281 SMBUS_SMC_BSA_SDA and SMC_BSA_SDA_SCL are both 3.4V
    on the ISL
    R7021 = 12 ohms
    R7022 =12 ohms
    R7051= 4.5 ohms think my multimeter can't go so low. When i touch my probes i get 2.3 ohms. So if i subtract that from the readings it will be good. So both R7051 and R7052 may be good.
    R7052= 2.4 ohms
    Pin 2= 16.2v
    Pin 3= 3.9v
    Pin 18= 12.2v
    Pin 17= 12.2v
    Pin 14= 3.193v
    Pin 23 = 12.22v
    Pin 24 = 12.56v
    Checked all the resistors around the ISL. They all read ok.Really don't know where else to check for any abnormal voltages or resistances. Unless maybe the SMC is still bad which i doubt cause i took it from the working board.And i did a very good reball job as i have the tools to do it.
    Hoping you guys can help.This is not a customer machine it's my spare board just wanted to solve it so that i can build my skill level. thanks.
    Last edited by platinumsteel; 06-30-2022, 05:32 PM. Reason: forgot to put board number
  • mon2
    • Dec 2019
    • 13871
    Re: Macbook Pro 2010 Not Charging
    Hi.
    1) Is the battery detected by the logic board ? Does the OS show the charge level of the battery ?
    2) With a battery installed and adapter connected, what is the voltage of the following points ?
    PPVBAT_G3H_CONN
    PPVBAT_G3H_CHGR_REG
    SYS_DETECT_L (pin # 5 on J6950 - battery connector)
    3) Next, remove all power / no battery. Meter in lowest resistance mode.
    a) Measure the resistance from PPVBAT_G3H_CHGR_REG -> pin # 18 of U7000. Try to measure at the IC to confirm the trace between these 2 points is present. R7051 is in series and that is ok.
    Resistance reading ?
    b) repeat the test but with PPVBAT_G3H_CHGR_R -> pin # 17 of U7000.
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      PPVBAT_G3H_CONN = 12.22v
      PPVBAT_G3H_CHGR_REG= 12.24v
      SYS_DETECT_L= 0V
      PPVBAT_G3H_CHGR_REG -> pin # 18 of U7000 = 4.7 ohms
      PPVBAT_G3H_CHGR_R -> pin # 17 of U7000 = 2.5 ohms
      PPVBAT_G3H_CHGR_R -> pin # 17 of U7000=2.5 ohms
      • mon2
        • Dec 2019
        • 13871
        Was the SMC taken from the same logic board model?
        https://youtu.be/83nIYK00uoM
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Yes ofcourse it was taken from the identical board my friend. i didn't even make a joke of it because i am scared of doing reballs on smc and if it was a customer board i may not of even touch it .lol And the board i took it from that SMC was good for sure and the board was doing 12.56v . So i find it strange i replaced the SMC and nothing changed still 12.23v . Thanks a lot for the video i will go over those areas he talked about. Maybe i will put back the original smc as a last resort and see how it goes.
          • mon2
            • Dec 2019
            • 13871
            I would consider to remain with the donor SMC since you know it was working -> apply flux and reflow the donor SMC on this board. With proper heating, make the BGA device 'dance' to correct any possible joints that are not seated properly underneath the device.
            The SMC is the housekeeper that needs to dial up the higher voltage on U7000 so focus on the SMC.
            • platinumsteel
              • May 2019
              • 234
              • Trinidad&Tobago
              Hi again my friend well i finally gave up today. This board is definitely determined to be a donor board. I reflowed the smc nothing changed. I took it off and put back the smc that it had on it initially. Nothing changed still 12.23v no matter what i do. But thanks for all the help i got some good practice on smc reballing anyway. So will use this board as a donor.I only have 2 more new ISL chips. Really don't want to risk it putting it on the board and it messes it up some how. I already have wasted 2x new ISL on this board already.thx again for the help.
              • piernov
                • Jan 2016
                • 4435
                • France
                https://www.badcaps.net/forum/showpo...50&postcount=2
                2.2.2. Battery not detected
                Issue on charging circuit SMBUS.
                Check voltage and diode mode to ground on charging circuit SMBUS SDA and SCL lines
                • platinumsteel
                  • May 2019
                  • 234
                  • Trinidad&Tobago
                  Okay thanks for this i had only checked voltage on the SDA and SCL lines but i just checked diode mode and it seems a little off. i compared those lines with a working 2012 board in diode mode
                  Trouble board:
                  SMBUS SDA: 0.517V
                  SMBUS SCL: 0.540V
                  Good Board:
                  SMBUS SDA:0.540v
                  SMBUS SCL: 0.542v
                  Will try changing one or both resistors or see what else on the line might be causing this and see if anything changes thanks a lot for pointing this out pier.
                  Will be sure to get back.
                  • mon2
                    • Dec 2019
                    • 13871
                    Remove D6950 and check the readings again.
                    • platinumsteel
                      • May 2019
                      • 234
                      • Trinidad&Tobago
                      Removed and checked diode mode on everything on the line also replaced the caps just in case specifically on the SMBUS_SMC_BSA_SCL and nothing changed keeps staying at 0.517V . I eventually caved in and put in my last ISL. Still was the same.I also removed the D6950 as you mentioned and checked but still same. Then decided to heat up the area of D6950 and put some alcohol and blow some air pressure to get under the battery connector then i saw diode mode went up a bit it went to 0.520v .maybe margin of error and means nothing. Think maybe i must of done something wrong and the SMC got bad as well. That is the only thing left i guess. I am thinking of removing the Bill connector off the board tho. Do i need it really. not really care about the led reading for the battery on this old model anyway.
                      • mon2
                        • Dec 2019
                        • 13871
                        Sorry - what is that ?
                        • platinumsteel
                          • May 2019
                          • 234
                          • Trinidad&Tobago
                          That is J6955 connector. There is a little led indicator to the side of the older macbook pros that shows how much charge the battery has. It has a connector for the LEDs . connector is right next to R5280 and R5281. The connector is connected to those SMBUS_SMC_BSA_SCL/SDA lines
                          • mon2
                            • Dec 2019
                            • 13871
                            hi.
                            1) each of the ISL devices from U7000 can be recirculated - they are QFN packaged devices so all you need to do is apply flux & desoldering braid to remove the excess solder off the bottom side of the IC and then you can use it again on future logic boards. So they are not being wasted.
                            2) now see the BIL connector - never heard of it before till you mentioned it. I am assuming that it will not be missed. As a FYI, a few years ago, many developers were stuck with an audio processor design (XMOS) where the USB engine would stop working with their custom design. After we reviewed the case(s), the USB engine was a software IP that demanded a certain amount of bandwidth from the XMOS CPU to operate. However, the engineers created their custom design using different parts on their design and missed out on the factory reference design which made use of certain I2C (SMBUS) peripherals. This on top of that they did NOT remove the code that pinged the hardware that was no longer present on the custom design. So the IP would boot, spend xxx clock cycles searching for an I2C (SMBUS) address of a device that was not present -> led to sucking away CPU time -> led to the USB IP breaking with many faults. This caused many audio devices to fail in the field.
                            So the summary and concern here is that with the BIL board removed - will the host (I2C / SMBUS Master = SMC) miss the presence of this board ? Or will it just search for it and continue on if the board is not present ? TBD...
                            3) At this time, the logic board works but will not charge the battery ? Does the Windows OS detect the battery ? Does it show the charge level of the battery ?
                            4) Understand that you have measured ~3v4 on the SMBUS lines used by U7000 but this only confirms that the lines are not stuck and that the local pull-up resistors are present on these SDA & SCL lines. This test does not confirm that the same pair of lines actually reach the SMC hidden balls.
                            Consider to remove all power -> perform a resistance check from the pull-up on the SDA line and trace it back to the battery connector pin for the same function.
                            Then repeat for the SCL line. This is a half baked but valid test to confirm there is no trace break between the points being tested. The real test would be to perform this test from the SMC ball (with the SMC device removed) and to the battery connector.
                            • platinumsteel
                              • May 2019
                              • 234
                              • Trinidad&Tobago
                              Would you believe that yesterday when i took off the smc i was going to do that same test but something came up and i completely forgot to do it. I doubt i will want to conduct that test and go over the whole reballing process.I am not lucky with using the paste. I want to order the balls and try that method instead for reballing. When i get that then will take off smc and conduct the test.But thanks a lot for mentioning that should of done that from the very start my bad.
                              • platinumsteel
                                • May 2019
                                • 234
                                • Trinidad&Tobago
                                Hi guys i ended up deciding to remove the bill connector.And low and behold there was a crater with corrosion i tried scraping off but it seems to be going deeper am not sure. Am not sure if this will definitely be my issue of that drop in diode mode measurement i have especially on the SDA line.
                                SDA 0.527V
                                SCL 0.550V
                                But do u guys think it will make sense if i try to get away from those viers? Like maybe remove the 2x resistors of their pad and run jumpers from the resistor directly to the capacitors to the back of the board . Like move the resistors of those 2 viers and run jumper wires directly to the back of the board so maybe i can bypass what ever short there is if atold there is a slight short?
                                • mon2
                                  • Dec 2019
                                  • 13871
                                  Hi. Ok, after a stare of the PCB, can see the pattern (I think).
                                  See attached. Does this look correct on the wiring ?
                                  TOP ARROW = SDA pin.
                                  BOTTOM ARROW = SCL pin.
                                  My suggestion:
                                  1) locate some single strand wire that is flexible.
                                  2) place one end of the strand where the connector pad is showing (SDA) -> apply a bit of flux and solder it in place. Cut off a few inches for the other side.
                                  3) repeat with another fresh strand for the SCL pad.
                                  4) Now apply the other side of the SDA wire to the SDA resistor to bypass the broken PCB trace.
                                  5) Repeat to fix the SCL pad with the SCL resistor in the same way.
                                  6) Now, apply the BIL connector ontop of this stack up and solder each connector pad back into place.
                                  So you are creating a sandwich to fix the 2 traces.
                                  These wires can be longer as it is a SLOW I2C (SMBUS) bus and often is 100khz (400khz max) so not a high speed interconnect.
                                  You can exit the wires from the REAR of the BIL connector (ie. to the LEFT side of your picture) and then around the connector to reach the local resistors.
                                  • DEVICHETAN
                                    • Jun 2021
                                    • 4
                                    • india
                                    MAC 820-2879 green light on mag , system running but not charging
                                    my SMBUS_CHGR_SDA is dropping from 3.4v to 0 and again regaining 3.4v continues in loop mode , battery not charging pls help
                                    u7000 pin 14 ACOK is 2.8v , is it correct?
                                    • mon2
                                      • Dec 2019
                                      • 13871
                                      1) be sure the adapter is the correct one for this laptop
                                      2) test with a known good battery
                                      • envym
                                        MacBook Pro 2018 with Activation Lock
                                        by envym
                                        Hi everyone!
                                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                        06-27-2025, 08:54 AM
                                        Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
                                        Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
                                        10-22-2024, 02:37 AM
                                      • tobeend
                                        Bypass mdm macbook m2 ventura
                                        by tobeend
                                        1. RESET MACOS WITH IPSW
                                        a. Power off MacBook, press and hold the power button to enter Recovery
                                        b. Open Disk Utility, remove Macintosh HD
                                        c. Reboot, connect to the network to Activate Mac.
                                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                        05-26-2023, 07:18 AM
                                      • SarcasticOP
                                        General question about MacBook power rails for repair.
                                        by SarcasticOP
                                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                        • PPBUS_G3H (12.6V-12.8V)
                                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                        • PP3V42_G3H (3.42V)
                                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                        • PPVRTC_G3H (3.3V)
                                          • This
                                        12-12-2024, 05:50 PM
                                      • vdrokko99
                                        MacBook Pro 15" 2010 820-2850 no PPBUS_G3H, green light on
                                        by vdrokko99
                                        I'd like to ask help to repair 820-2850. There is green light, but not turning on because the PPVBUS_G3H is 0.5xxx V. I already measured resistance to GND, but no short ciurcuit. I did a few measure next to U7000,
                                        R7020 ok,
                                        R7050 ok,
                                        F7040 ok,
                                        SCM_RESET_L 3,4V
                                        CHRG_DCIN 16V,
                                        PP5V1_CHGR_VDD, and PP5V1_CHGR_VDDP is 0,5V but no short to GND
                                        I think the missing PP5V1_CHGR_VDD is the problem which is comes from and go to the U7000.
                                        This missing voltage means a defective U7000 or cause other missing voltage?...
                                        12-05-2024, 08:23 AM
