Harddrive motherboard
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    I have a quick question, I have the harddrive that is spinning but doesn't detect on any machine , it spins very we but not showing even on disk management.
    It a western digital, so I suspect the board or maybe corrupted bios or faulty chip
    , can I use another same identical drive and see if it will work?
  • mielta
    • Apr 2015
    • 368
    Re: Harddrive motherboard
    Hi
    Yes you can but you must change the Bioschip from the old one
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone ๐Ÿ˜€,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just โ‚ฌ150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
      ASUS P5GC-MX motherboard recap
      by momaka
      Hereโ€™s another motherboard that needed a full recap: an ASUS P5GC-MX.
      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF capsโ€ฆ which arenโ€™t any good news either.
      So here is what the motherboard looked like with its original caps:
      CPU VRM area up closeโ€ฆ...
      01-27-2021, 11:59 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • dhenion
      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
      by dhenion
      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
      The original board was:
      ASUS X510UNR REV 3.0 A
      The replacement board is:
      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
      01-30-2024, 01:45 PM
