Dell inspiron 3542 keyoard not working
  • musanide
    JQUB
    • May 2020
    • 86
    • zambia
    i have a dell inspiron 3542, the keyboard works with all the keys when the laptop turns on, i even go into the Bios setup and do all that i want, but once the Os start to load the keyboard stops working completely.. I have tried the following diagnostics:-
    1.Installed different versions of windows os.
    2.Installed Ubuntu Os
    3.Update Keyboard drivers from the official dell website
    4.Tried different keyboards.
    5.Updated Bios firmware.
    6.Flashed a new Bios firmware and even changed the Bios Chip
    and yet the keyboard couldnt start working normally, any help or advice will be highly appreciated..
  • mon2
    • Dec 2019
    • 14333
    Re: Dell inspiron 3542 keyoard not working
    Sounds like some type of a security lock.
    Have you tested with a SAFE MODE of Windows OS boot ?
    • musanide
      JQUB
      • May 2020
      • 86
      • zambia
      i have not tried safe mode, i will try it today
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Had a look on KBC pins and kbd connector for corrosion/liquid damage??
        • mon2
          • Dec 2019
          • 14333
          Keyboard works fine in BIOS mode; halts when any OS starts to load. Suspecting it is some security trigger.
          • musanide
            JQUB
            • May 2020
            • 86
            • zambia
            tried the safe mode with windows 10 still no response,,, and the thing is the keyboard becomes completely off when the os starts to load until it fully loads.. not even a single key works ,, and when i check from the DEVICE MANAGER it shows me the standard ps/2 keyboard.
            • musanide
              JQUB
              • May 2020
              • 86
              • zambia
              there is no sign of corrosion or water damage on the KBC or on the MB, and the keyboard works in bios and without OS, but once the os starts to load,it stops
                • 21173
                Did you notice when this started happening,was it after a windows update
                • mon2
                  • Dec 2019
                  • 14333
                  Doubt that you have a PS/2 keyboard.
                  It should be operating using the internal KBC controller IC.
                  Attach an external usb keyboard and see if that works for you.
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • zlr8r
                    looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                    by zlr8r
                    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                    cheers
                    Dell Inspiron 17 (7786) Laptop
                    Service Tag: 5J0NHT2
                    Bios: 1.9.0
                    MOBO: RO 15 17 WHL 2GB MB / 18706-2
                    Attached;
                    1. My saved bios using a programmer
                    2. Dells Bios updater .exe (v1.16)
                    3. Dells Bios recovery file
                    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                    5. Image of ME...
                    12-18-2023, 03:08 PM
                  • GadgetsFix
                    Dell Inspiron 16 5630 BIOS request
                    by GadgetsFix
                    I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                    • Model: Dell Inspiron 16 5630
                    • MainBoard Part Number: 4550SC01C004
                    • Laptop Serial No: GKH3JX3
                    • DP/N: 0303KM
                    • QUAKE N RPL UMA CS MB
                    • 213251-2
                    • TMN0H$KB
                    01-17-2025, 07:38 AM
                  • computerbacon79
                    Dell Inspiron 3480 All in One corrupt Bios issue
                    by computerbacon79
                    The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                    05-06-2025, 06:43 PM
                  • shugu1701
                    dell inspiron 15 7510 bios
                    by shugu1701
                    Hello, i have a dell inspiron 15 7510 g48c0$la was not turning on at all and i couldnt find the right bios but with a bios for almost the same model it turn on, cpu warm up fan spin but no picture, so i gess if someone can repair my bios it should be fine.
                    spec: dell inspiron 15 7510 g48c0$la
                    servicetag 6p70dl3
                    reg type p106f002
                    i link the original bios
                    thank you...
                    11-06-2024, 07:45 AM
