How can we prevent 19v entering SOC?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Forum Members,
    When the high side Mosfet gets shorted, the 19v power easily enters the CPU or PCH without any protection.
    I think the buck-converter circuits in laptops should be modified somehow to protect the SOC against 19v when the high side Mosfet gets shorted.
    How can we do that?
    Can we put a safe isolation between the buck converter circuit and the SOC so that no failure in the buck converter circuit damages the SOC?
    note: The solution will be useful for both repairmen and manufacturers.
  • petehall347
    • Jan 2015
    • 4440
    Re: How can we prevent 19v entering SOC?
    clamp or crowbar spring to mind
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Manufacturers knows the solution and have all the know how to implement it but the fact of the matter is they dont want to do it. The aim is simple-so that it doesnt last long enough. A HP loyalist who have faced this type of failure will swear not to buy a HP again and may go for rival brand. But the same happens with other brands-So no brands are actually affected in terms of sale.
      Dont think much about the issue-accept it as new reality.
      • reformatt
        • Feb 2020
        • 1491
        The OEM's could put an avalanche diode or some other voltage transient device in there if they wanted to. But they don't. And they could have insisted Intel et al to keep using socketed designs rather than BGA so we could just swap out or even upgrade.
        It's built in obsolescence. Repairs are just a necessary evil, people expect it. But the preference would be just swap out devices or replace. Then they don't need to keep parts on hand, warehousing etc. This is the price we pay for new models every year.
        • Udemzy
          • May 2017
          • 163
          • Guatemala
          The truth whether HP,dell or Lenovo etc,this mobo are not manufactured by them.
          • piernov
            • Jan 2016
            • 4439
            • France
            It's not easy. TVS diodes are not perfect: they do not act instantaneously, the I/V slope isn't perfectly straight, they do not have tight tolerances and they'd need to dissipate an insane amount of power before burning.
            There may be a better solution to this problem, I'm not an electrical engineer, but I don't know what it is.
            • mon2
              • 14659
              HP and Dell are built by Foxconn. We have been working with Foxconn as a supplier for 20+ years but these are their designs and their BOM. They integrate our products into theirs.
              Would an add-on pcb be a solution?
              What are the dimension restrictions?
              Initial quick thought is to detect the transient and shutdown the charger IC to halt the first 2 mofets.
              Not clear but can ask TI as to how many cycles will transpire before the mosfets shutdown.
              Just random thoughts...
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                I did some research and studied that isolation is often implemented in AC circuits.
                In DC circuits, I have not found any practical isolation technique yet that can be used in the restricted space of a laptop mainboard.
                Having Socket-based SOC is the most efficient solution that does not need any extra protection circuit.
                • Manuel S.
                  Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
                  by Manuel S.
                  my Lenovo 720 is dead. :-(
                  I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
                  Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
                  When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
                  The EN1 is completely off 0V, EN2 show 1.5V.
                  If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
                  BS seams SHORT to the OUT....
                  03-14-2024, 05:17 PM
                • caspian
                  Too much current from a Buck Converter
                  by caspian
                  Dear members,
                  Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
                  Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
                  PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback...
                  05-29-2020, 06:41 AM
                • adamski1952
                  ps5 shorted after buck converter
                  by adamski1952
                  Hi.all.
                  Working on a PS5 EDM-010 motherboard and i've located a short after the TLV62090RGTR 5v to 3.3v chip directly behind F7002.same chip i think. I've removed the chip thinking that was the problem but the short is still there.I injected 1v at 1 amp on output coil (arrowed in picture) but nothing shows up on my thermal camera. No boardview so I because I dont know which rail it feeds i'm reluctant to up the power injection.I could use some help with this if anone has any ideas. ...
                  12-18-2024, 08:25 PM
                • piernov
                  Laptop battery charging circuit
                  by piernov
                  1. Some theory
                  1.1. Introduction
                  Almost every laptop has a charging circuit of some sort, that does a few things:
                  • Manages switching between AC adapter and battery power
                  • Manages battery charging and generates power rail to charge battery
                  There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                  • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                  • Narrow VDC (NVDC)
                  Texas instrument has a nice overview of these technologies with some more details at https:...
                  11-15-2020, 01:31 PM
                • Thetechdude
                  Repair help. Zotac trinity 4070ti 12G 3x
                  by Thetechdude
                  Hi Guys.
                  Here I have a 4070ti with some issues.
                  When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
                  Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
                  Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
                  Resistances:...
                  09-07-2025, 07:49 AM
