A1708 - Problem With Display - Driving Me Insane
  • Ado02
    • Jul 2021
    • 100
    I am working on an A1708 MacBook Pro 13 / Mid 2017 with a keyboard problem. I replaced the palmrest and installed a new battery, which is when the fan started.
    When powering on the MacBook, the fan would spin for a few seconds and go off, and nothing would show off on the screen. However, when I disconnected the battery, the laptop would work.
    So, I ordered a new battery, but the problem was the same. I spent hours figuring out the problem, but the logic board eventually stopped working.
    The next step was to order a replacement logic board - but the same problem was present. So, I ordered another palmrest and battery. The problem is still present.
    I even replaced the trackpad and the screen, but the problem didn't go.
    Today - I figured out that powering on the laptop first without the battery, shutting it down, and adding the battery resolved the problem. However, I now have a new issue.
    When I close the screen and open it again, the screen will not come on. The keyboard backlight is on as normal. When this happens, I must disconnect the battery and go through the same process.
    Please help me! Someone must have gone through this and come out on the other side.
  • mon2
    • 14662
    Re: A1708 - Problem With Display - Driving Me Insane
    Fairly sure this model is linked to flexgate.
    https://logi.wiki/index.php/A1706/A1...nout_(FlexGate)
    Depending on how loud you can yell & scream at Apple, you should be able to get it covered under warranty.
    Also demand that they replace the wimpy butterfly keyboard which will give you / client issues.
    We have done this with success for numerous end customers - Apple replaced the keyboard assembly & case as well as the display assembly under warranty.
    • Ado02
      • Jul 2021
      • 100
      Thank you for your reply. It's not the screen because I have tried 3 differents screens and the problem was the same.
      • mon2
        • 14662
        Can you see the graphics on any of the tested display panels ? Use a flashlight / phone torch and view at assorted angles to see if the panel is working.
        You have replaced the palmrest which is linked to the lidswitch.
        Are you using the same flex cables as the original or were they replaced ?
        With power off, carefully review the seating of the palmrest cabling.
        You can try without the palmrest connected - remove the cable from the logic board and test again.
        What is the voltage of LID_OPEN when the lid is open and the palmrest is connected ?
        • 100FIX
          A1708 peculiar bms problem.
          by 100FIX
          Hi, I have a mbp a1708 2017 that I am trying to fix.
          (1.) It turns on fine on ac power when bms flex is unplugged.
          (2.) I noticed when battery & charger is unplugged and reconnected, it turns on only after a few minutes but doesn't stay on battery power i.e. it turns off as soon as charger is unplugged and doesn't turn on until (2.) is repeated. During this time, health information and charging information are displayed and normal and battery charges but laptop turns off as soon as charger is disconnected.
          I have reballed u7000, problem persists.
          07-16-2024, 01:35 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Jacksoft
          Apple A1708 charging problem
          by Jacksoft
          we have a MacBook Pro A1708 with board 820-00840-A that initially had U3200 (one of the CD3215C00) in short. We replaced both and now on one Type-C port charger goes up to 20V and on the battery pin the we have about 12V, but on the other port the charge is stuck to 5V with no PP3V3_G3H (that's strange). Already checked resistors and capacitors solder and all seems ok.
          We found that when, on the other port, the voltage goes up to 20V this value is present on both U3100 and U3200 caps (C3101 and C3201) that should not (am I right?), so Q3100 or Q3200 is in short (we still...
          02-10-2023, 10:29 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
