ASUS ViviBook X512F no power
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS ViviBook X512F no power
    Replace the 2nd mosfet, dont replace the charging IC now. Power up, what is the status?? CLR stands for Current Sensing Resistor usually located just after the 2nd dc-in mosfet.
    • sect-sin
      • May 2022
      • 101
      • Hungary
      mcplslg123,
      Thanks for the additional info. Tonight I will search for the current sense resistor as well, just to be on the safe side, and in order to learn more. Am I right in assuming that it should have a low value to begin with? Would it connect the Gate with the Source, or something else?
      Cheers,
      sect-sin
      • mon2
        • 14684
        https://youtu.be/vgeVpYWkwBM
        • Simplebeans
          • Sep 2021
          • 135
          Originally posted by sect-sin
          Simplebeans,
          I got the 2.1 revision of the board, the area looks exactly the same like on the 2.2 version. I measured the component out of circuit, it is definietly a 0 ohm resistor.
          I have the exact same problem with my board, and wish us both good luck to fix it.
          Cheers,
          sect-sin
          Hi thanks and appreciate your help on the 0Ω resistor, at least we know what that part is now.
          Do you have any schematics for this board at all?
          • sect-sin
            • May 2022
            • 101
            • Hungary
            None at all. For the majority of stuff I repair or try to repair, there seems to be no documentation at all.
            • Simplebeans
              • Sep 2021
              • 135
              Haha thats why its nice working on Macbooks, there is always a schematic(s).
              • Simplebeans
                • Sep 2021
                • 135
                OK. Lets make simple checks to begin with.
                01.Measure voltage on Pin1-4-8 of dc-in mosfets.
                02.Measure resistance on CLR.
                03.Measure charging IC pins for ACN/ACP/CMSRC/ACOK/ACDET/REGN/VCC
                01) The first mosfet in the dc-in circuit at the drain, source all measure 19V and the gate measures 24V. The power reaches the second mosfet, there at the drain then measures at 19V however no voltages measure on the source/gate side of second mosfet.
                02) The main current sense resistor i can see, is placed near the first mosfet in the dc-in circuit, the resistance at this resistor (meter is resistance mode 20MΩ), black probe to ground point and red probe to PIN #1/2 @ the resistor measures 3.2MΩ and rising.
                03) The voltage measurements at the charging IC (TI BQ24780S chip):
                ACN= 19.43V
                ACP= 19.42V
                CMSRC= 18.96V
                ACOK= 5.95V
                ACDET= 2.64V
                REGN= 6.00V
                VCC= 19.21V
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  The charging IC measurement seems fine. There should be voltage on the source of 2nd fet as you are aware. Confirm it by measuring on CLR?? There should not be any voltage here in your case. Is the battery discharge fet not shorted??
                  • Simplebeans
                    • Sep 2021
                    • 135
                    Yes i just measured and the current sense resistor which does have a measurement of 19V on both sides of it, PIN's #1 and #2 respectively.
                    I have just noticed something interesting that i may not have noticed previously. So the first dc in mosfet (M3056M) when measuring resistance from S-G: i get 97KΩ however the second mosfet (M3054M) S-G measures 2.6KΩ. The interesting thing is all the other mosfets in the circuit after these mosfets, that i have mesured so far are showing all at around a 7.3KΩ measurement at the S-G. This is the only anomoly however that i am noticing at present.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      You should replace the 2nd mosfet first before troubleshooting further. Probing further without replacing it may be futile and pure waste of time.
                      • Simplebeans
                        • Sep 2021
                        • 135
                        Ok 2nd mosfet issue now resolved, resistance readings are good now. Still no power.
                        • Sephir0th
                          • Oct 2020
                          • 1289
                          New overview necessary since you have 19V at the main power rail now.
                          Any coil which have voltage? 3.3V at the power button by any chance?
                          FairRepair on YouTube
                          • Simplebeans
                            • Sep 2021
                            • 135
                            I appreciate your input but really not sure what you mean? The status of the machine has not changed (apart from replacing a mosfet), the voltage measurements are all the same as when i started this thread. The only inductor that has a voltage reading is the one right near the charger IC. All the other inductors are showing 0V.
                            • sect-sin
                              • May 2022
                              • 101
                              • Hungary
                              #34
                              Hello everybody,
                              Today finally the replacement MOSFETs arrived from China. I started with replacing QM0930M since it had the dead short, and voilá, the notebook runs again! One more machine saved from e-waste, I am so happy!
                              I thank you very much for your help and support, I really appreciate you guys.
                              Cheers,
                              sect-sin
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • ShadowAi
                                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                by ShadowAi
                                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                03-15-2024, 10:46 AM
                              • meraklinetx
                                Asus Z97-a power cycle, no boot no cpu voltage
                                by meraklinetx
                                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                05-10-2023, 06:08 AM
