HP 15-BW la-e831p vga problem.
  • quic307
    • Jun 2015
    • 255
    • Greece
    Hello techs,
    I have the la-e831p rev 2.0 DISCRETE (216-0864032-AM972PADY44AB) and I have problem with the vga and the vram's.
    I want to disable the vga and to make the MB uma, la-e831p rev 1.0 UMA.
    Any info how to do that? I don't have the schem to check it.
    Thank you in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-BW la-e831p vga problem.
    Try removing GPU power coils.
    • quic307
      • Jun 2015
      • 255
      • Greece
      I removed the coils and then no signal ... probably takes feedback from coils or something like that ....
      I attached the 3 coils which I remove.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I think removing those 3 coils will make it UMA(LA-E801P, uma works by removing these 3 coils). The board looks very similar to LA-E801P and only the platform differs-INtel Vs AMD. Are you sure where problem is not somewhere else??
        • quic307
          • Jun 2015
          • 255
          • Greece
          I found the same board "UMA" and I found some different's, in red circle "QOD1 and QOD2". I removed the 3 coils and put the "QOD1 and QOD2" from other damaged mobo. No signal.
          Now I'm looking for schematic.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            What is your problem?? Turning on but no display?? If yes, then post measurements on all coils.
            • kasun nirosh
              • sri lanka
              Any one still looking for dis to uma conversion on La-e831p board here s what you need to do . first disconnect pjv1 and pjw1 . then move the resister as in the photo. thats all you need to do ( you can remove or keep pwm ic coils or mosfets ) .
              • madushanka 1234
                • Apr 2019
                • 55
                • sri lanka
                kasun nirosh​
                its working method for La-e831p >>> great work brother..
                tested ok
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • abobek zum
                  Legion 5 15ACH6A powered ON but no display
                  by abobek zum
                  I have a question regarding this laptop. Laptop came from my friend, completely dead. No reaction for power button, Adpater etc. Diagnosis: burned HIS mostfet from VRAMs. After replacing the mosfet, Laptop starts to power up, KB lights up for few second and switch off, laptop remain ON but no display. Vents are switching ON after some time. No Caps Lock or reaction on USB stick. No display also through HDMI. All coils resistance seems to be OK except resistance on VRAMs – 15 Ohm ( as I study the other repairs or diagnostic of that laptop it should be around 90 -...
                  03-03-2025, 04:34 PM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
