Asus P553UJ rev 2.0 no power
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    what to check ? i found brd , schematics are avaiable ?
  • mon2
    • 14659
    Re: Asus P553UJ rev 2.0 no power
    No schematics for this Asus. Repair guide is floating on paid services.
    Review the many threads on Asus repairs. It will be the same procedure. No schematics are needed.
      • 21841
      repair guide screenshot from a web page https://www.badcaps.net/forum/showthread.php?p=1141118
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        thanks
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
          05-29-2024, 02:01 PM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
        • conghuyms
          Request for Help – ASUS G531GW Rev 1.6 – No Power On
          by conghuyms
          I need your support with an ASUS G531GW Rev 1.6 laptop.
          When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
          Here’s what I’ve checked so far:
          • Motherboard has been removed for inspection.
          • 3V and 5V always-on rails are present (3V/5V_ALW).
          • 1.8V and 1.09V at the PCH are present.
          • I don’t have the boardview/schematic, so troubleshooting is limited.
          • I tried checking the power button signal from the
          07-20-2025, 09:14 PM
