ASUS X455L Battery not detected problem.
This topic has been answered.
  • bustacaps
    • Jun 2022
    • 7
    • Philippines
    Hello everyone, my problem goes like this... I have Asus X455L laptop. Initial problem was battery not detected so I replaced it with a new battery but still not detected and since it was not detected it was not charging. The battery led(orange) indicator keeps blinking. When pressing power button without plugging the adapter it WON'T turn-on with the new battery installed. But when I plugged the adapter it turned-on immediately(not pressing power button anymore). The laptop has display by the way. Also I noticed the fan spinning fast(I can hear its sound).
    The troubleshooting I've done so far are: Software related(not working), Checked the motherboard battery pins voltages pin1&2(+terminal)=0.9V,pin3(SMB0_DAT_CLK_CON)=3V, pin4(SMB0_DAT_BAT_CON)=0V, pin5(P_RTC_LDO3V3)=0V, pin6,7,&8(GND).
    Can someone please help or guide me to exactly pin point the bad component?. Because my first thought it was the charger IC(BQ735) but I'm hesitant replacing it. I just want to be sure. Thank you so much in advance!
  • Answer selected by bustacaps at 02-02-2025, 09:13 AM.
    henr
    • Oct 2023
    • 4
    • indonesia
    Hi after 2 years did you solve it?, i have the same problem . Battery not detected on asus x455ld rev 2.1 . I bought this old 2014 laptop with no display, fan spinning fast, orange battery led kept blinking .. the selller said he bought new battery but not detected . i had 5 donor boards exact model. what i did was
    replace bios. Display comes up
    next i changed bq735 ic . battery terminal only 2.5v instead of 12.56v on normal board.
    Next , replaced super io Ene kb9018 A3 from donor boards . Battery detected, batt terminal voltage becomes 12.56v , charging fine, fan spin normal. battery oramge led steady .
    • mon2
      • Dec 2019
      • 14795
      Re: ASUS X455L Battery not detected problem.
      This is not correct for this signal.
      Remove all power. Meter in resistance mode.
      Check the resistance to ground of this signal. You may have a shorted esd diode on this signal line.
      Review the resistance and hunt for an ESD protection diode on this line. If found, remove it off the board and check the voltage again. It should be ~3 volts.
      • bustacaps
        • Jun 2022
        • 7
        • Philippines
        I have done what you instructed sir. But upon checking with also the guidance of the boardview. The diode connected to that line was PD6001. Most probably that was the esd protection diode but the thing is its NOT THERE.
        • mon2
          • Dec 2019
          • 14795
          For the same signal, check it's resistance to ground.
          Remove all power.
          Meter probe on this same pin.
          Other meter probe to ground.
          What is the resistance?
          • mon2
            • Dec 2019
            • 14795
            See attached.
            Between the battery connector and this missing ESD diode network, there should be a series 330 ohm resistor.
            Check the resistance from the one side of this series resistor and the battery connector.
            What is the resistance in ohms ? Measure between the 2 yellow arrows.
            • bustacaps
              • Jun 2022
              • 7
              • Philippines
              Remove all power.
              Sorry for the late reply sir,
              BTW the resistance between pin4 to GND= 325ohms.
              • bustacaps
                • Jun 2022
                • 7
                • Philippines
                See attached.
                Yes, there is a 330ohm resistor. It reads 324ohms.
                The one side of this series resistor(PR6001) and the battery connector(pin4)=324ohms.
                RN3001 is present and not corroded it reads--4k25ohms on those pins you indicated.
                PSL8802 to pin4 is 342ohms.
                It seems all values are good sir...
                • bustacaps
                  • Jun 2022
                  • 7
                  • Philippines
                  Now I'll try to measure the pin voltages for BQ735 charging ic to see any incorrect output.
                  Anyone knows, what will be the expected output for each pin?
                  So that I can compare my reading...
                  • henr
                    • Oct 2023
                    • 4
                    • indonesia
                    • bustacaps
                      • Jun 2022
                      • 7
                      • Philippines
                      Wow! that is great to know. I haven't solved it. Thank you for the information.
                      • dhenion
                        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                        by dhenion
                        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                        The original board was:
                        ASUS X510UNR REV 3.0 A
                        The replacement board is:
                        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                        01-30-2024, 01:45 PM
                      • ahmarzo
                        Acer TMX314-51 laptop battery problem
                        by ahmarzo
                        I have acer laptop tmx314-51 with part no 6050A3020501.
                        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                        The schematic is not available...
                        04-11-2025, 09:14 AM
                      • mrkmpn
                        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                        by mrkmpn
                        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                        03-13-2024, 01:54 PM
                      • cope
                        Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                        by cope
                        I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                        Some history:
                        Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                        As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                        Now, with a new battery the system will start up and run off...
                        05-13-2024, 09:40 AM
                      • silver60618
                        Macbook Pro A1990 - Battery not detected after connector torn off
                        by silver60618
                        Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                        Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                        11-12-2025, 06:36 PM
