Asus x450ep rev 2.0 touchpad synaptics not detect
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hi friends, I hope someone can help me with this asus x450ep rev 2.0 mobo case, the problem is the touchpad doesn't work, I've tried with another asus touchpad, but still, I've never got this touchpad case, I'm confused where to measure from
  • mon2
    • Dec 2019
    • 14662
    Re: Asus x450ep rev 2.0 touchpad synaptics not detect
    See attached. Review the yellow arrows -> remove all power -> meter in resistance mode -> red meter lead on the yellow arrow head point; black meter lead to ground.
    What is the resistance for the SCL & SDA pins used by the trackpad ?
    Post the resistance measurements and scale on the meter used.
    Next, multimeter in DC volts mode (5 volts or higher is ok).
    Measure the voltage on the SCL & SDA pins to ground.
    Post the voltage measurements for each pin.
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      both patterns display infinite values sir, in buzzer mode and the position of the red probe on gnd and the black probe on pin
      I need to say that these pins are not filled with IC
      • Yosua
        • Jun 2021
        • 221
        • Indonesia
        and I've measured the volt parameter, the result on pin number 6 (DATA) when using the touchpad displays 0.70v, if not using the touchpad is 3.3v sir
        • mon2
          • Dec 2019
          • 14662
          The measurements were not taken correctly.
          Configure the multimeter in DC volts mode (5 volts or higher scale is ok).
          Red meter probe on the point to measure; black meter probe to ground.
          Apply power to the logic board. We wish to know the voltage on the SDA and then the SCL lines to see if they are stuck or not.
          If either of these lines is stuck, this could be the fault.
          The mode you referenced is the diode mode testing.
          • Yosua
            • Jun 2021
            • 221
            • Indonesia
            when using touchpad
            PIN 3 = 0.63V
            PIN 4 = 0.45V
            and when touchpad is removed is 0v sir
            • mon2
              • Dec 2019
              • 14662
              These are not good voltage readings.
              See attached. Locate RN3002 and measure the voltage on the RIGHT side of this resistor network.
              Inside this resistor network are 2 * 4k7 resistors that are acting as pull-ups. The pull-up voltage must be 3v3 for each pin.
              Confirm the voltage readings.
              The LEFT side are the same SCL & SDA pins used for the trackpad. These are the TP_DAT & TP_CLK lines.
              Measure these as well and post all readings.
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                Sorry sir I just replied because yesterday I had to work
                sorry but on this mobo there is no RN3002, are you not wrong to open boardview?
                • mon2
                  • Dec 2019
                  • 14662
                  Can you post a picture of your logic board near the touchpad connector?
                  Then will see it matches my boardview file.
                  For the missing resistor network, do you see the pads?
                  Maybe share a pic of that area as well.
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    The touchpad is detached
                    TP CLK = 0v
                    TP DAT = 3V
                    Touchpad installed condition
                    TP CLK = 0V
                    TP DAT = 0.69V
                    this measurement on RN5202 near KBC
                    • Yosua
                      • Jun 2021
                      • 221
                      • Indonesia
                      Ini pak
                      • mon2
                        • Dec 2019
                        • 14662
                        Can you confirm the following ?
                        The touch pad connector on the logic board and the mating cables have a polarity.
                        Remove the touch pad cable and flip it upside down (ie. 180 degrees) unless you are 100% sure the cable is inserted in the proper orientation.
                        • Yosua
                          • Jun 2021
                          • 221
                          • Indonesia
                          the direction of the touchpad cable is correct, sir, that's it, I will order a touchpad that fits this type of mobo to make it easier, the touchpad is really not a problem
                          • mon2
                            • Dec 2019
                            • 14662
                            Review the ESD protection device that should be present on your logic board.
                            See attached. If you do see this part, proceed to check the resistance to GROUND.
                            Test as follows:
                            1) Remove all power.
                            2) Meter in resistance mode (start with the lowest scale). If you see '1' or 'OL' then use the next higher scale on your meter.
                            3) One meter probe to ground.
                            4) Other meter probe to DATA pin. You can use either probe - resistance does not have a polarity.
                            What is the reading ?
                            5) Repeat but use the meter probe on CLK and GROUND.
                            Do you have hot air gun & flux + tweezers ?
                            Update comment: Remain to test with the original touchpad unless you are 100% sure the replacement from the other Asus is the same model and compatible. Continue to test the communication lines because the voltages you have read are not correct for the I2C / SMBUS lines (CLK & DATA).
                            • Yosua
                              • Jun 2021
                              • 221
                              • Indonesia
                              Test as follows:
                              it's true that the touchpad doesn't matter, I've installed the new x450 touchpad, it still doesn't work sir,
                              and this is for the measurement in 20k . mode
                              Data Pins = 12k ohm
                              pin SDA = infinite
                              Yes sir, I have a hot air gun and flux so what steps should I take
                              And I tried to inject 3v voltage on the DATA pin with the MOSFET installed, the result is that the IC on the touchpad is very hot, on the original touchpad and the new touchpad it's the same
                              • Yosua
                                • Jun 2021
                                • 221
                                • Indonesia
                                Any one can healp me?
                                • mon2
                                  • Dec 2019
                                  • 14662
                                  Can you confirm again if D3106 is on your logic board ?
                                  Next, remove all power. Meter in resistance mode.
                                  Check the resistance to ground for the following pins on the touchpad connector:
                                  Pin # 2 O_TP_SCLK
                                  Pin # 3 O_TP_SDA
                                  Pin # 5 O_TP_DATA
                                  Pin # 6 O_TP_CLK
                                  After the resistance check -> meter in voltage mode -> check the voltage of the same pins.
                                  Post the resistance and voltage checks. When checking resistance - NO POWER !!
                                  • Yosua
                                    • Jun 2021
                                    • 221
                                    • Indonesia
                                    no sir this is empty
                                    • mon2
                                      • Dec 2019
                                      • 14662
                                      Is it the TOUCHPAD enabled in the BIOS ?
                                      Try to enter the BIOS -> toggle the setting for the TOUCHPAD -> save it -> exit -> enter the BIOS again -> enable the TOUCHPAD -> save and test again.
                                      • Yosua
                                        • Jun 2021
                                        • 221
                                        • Indonesia
                                        I have set the touchpad settings in the bios enable sir
                                        • rheyntau
                                          ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
                                          by rheyntau
                                          CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
                                          07-06-2025, 07:22 AM
                                        • jamesp
                                          Asus TP412FA keyboard and touchpad not functioning
                                          by jamesp
                                          Hello guys,
                                          need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
                                          since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
                                          08-18-2024, 11:02 AM
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-07-2024, 02:50 AM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
