Lenovo 320 NM-b241 memory issue.
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    NM-b241 don't Power on completely , just 0.160 amp .
    On board Ram
    After taken some measurements , followig the power sequence PG47 , i reach only step 7...didn't find anything about step 8...at step 9 SUSP# is 0v ( enable signal for many steps )
    i find too that PL501 is short to GND = 0.006 ohm ...so my suspecion go straight to this 4 little Samsung Semiconductor..
    When i open this jumper PJ507 (= +1.2V ) the short is not from PU500..the consumption go to 0.950 amp than the lap is off .
    So , i disable the ON BOARD RAM by shifting this 2 resistors :
    RC1634 to RC1631
    RC1635 to RC1632
    After Closing the jumber PJ507 the short still there.
    Don't want to remove this 4 little ram , is there anyway to confirm that the short is not from this 4 little ram !
    Thank you
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Lenovo 320 NM-b241 memory issue.
    Update : unfortunately it was the CPU.
    1.2v suplly both Ram and Cpu
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • db80
      Lenovo Ideapad 5 15ARE05 startup issue
      by db80
      Hello friends,
      I've been racking my brain over the past few months on the following issue:
      I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
      If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
      Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
      I tried all the common alleged „fixes“...
      07-06-2024, 05:58 PM
    • totof
      Lenovo Ideapad 3 15ALC6 motherboard issue
      by totof
      I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
      Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
      When I opened it, I noticed three burnt components near...
      Today, 10:27 AM
    • survivalbloke
      Need help pinpointing my short on this board (Lenovo) NM-D351
      by survivalbloke
      This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
      03-23-2024, 11:24 AM
