Acer A315-55G / DA0ZAWMB8E0 not charging [SOLVED]
  • mon2
    replied
    Re: Acer A315-55G / DA0ZAWMB8E0 not charging
    Check the resistance to ground of each large coil. Remove all power.
    Something is causing the power rail to shutdown. Start with the 3v3 rail used for the ILIM pin.
  • vannix
    replied
    Originally posted by mon2
    This is odd and believe it should not be 0v. Will review a bit later. See the datasheet for details of this pin. If 0v, there is nothing to do.
    In the datasheet i don't find detailed info, and even online there isn't information for 24780s related to ilim.
    However when +VIN is present there is 3.3v on +3VPCU and this brings power to ILIM. I therefore believe that it is not essential for enabling ACDRV.
    It could be a cap or a resistor that is damaged somewhere but i'm starting to get bored and there are many more repairs in the queue
  • mon2
    replied
  • vannix
    replied
    What is the voltage of pin #21 = ILIM ?
    This must be a ref voltage value > 0v to function.
    pin 21 ilim is 0,049mv, but PR15 is not present in this board
  • mon2
    replied
  • vannix
    replied
    Sorry for double post but i can't edit anymore the last one..
    Some updates:
    1) The ACIN pin in the ITE chip is probably programmable as input/output, when the EC is powered on i read 2,8v, so the chip should be ok.
    2) There isn't any mechanical problem (i think). I tried folding, heating or cooling and nothing changed.
    3) When the dc voltage is less than 17v (acdet < 2,4v) the ACOK is floating and is not pulled low. increasing input voltage, after about half a second that acdet > 2.4v, the acok pin goes low.
    In this time sometimes there is an instant where there is 2-4v after the 2 mosfets pq1 and pq9054. then it returns slowly to 0v (probably for capacitor discharge).
    At this point i believe there are 3 options:
    -a) the 24780s chip is fake, it doesn't work, the chinese programmer who engineered it was drunk
    -b) the 24780s chip must be programmed using smbus or internal registers as mentioned in the datasheet
    -c) there is a problem with some component in the charging circuit and the 24780s goes into protection immediately (paragraph "7.3.9 Device Protections Features" of the manual)
  • vannix
    replied
    OMG.
    1) Were the chips sourced through Aliexpress ?
    here are some shops we trust and have used often:
    https://www.aliexpress.com/item/3279...05588192%21sea
    https://www.aliexpress.com/item/3286...36471688%21sea
    https://www.aliexpress.com/item/1005...76906162%21sea
    2) You are in pretty deep on this repair - perhaps consider one more trace cut to isolate the ITE EC ? Then we will know with confidence that the voltage divider must match what was calculated.
    After this validation, consider to order a fresh batch of the charger IC and maybe even the ITE controller from another shop.
    yes, from aliexpress, but from another seller
    i can try to isolate the EC, however.. a strange thing happened. I disconnected the power supply from the 220v, after some seconds (when the 19v voltage started to drop) i touch the 19v connector and i'm sure that the fan starting spin for an instant. Tried again and again with the tester connected, but only another time happened that just inserted the power supply i read about 8v after the pq9054. this means that pq1 and pq9054 have been closed for an instant!
    probably something goes into overvoltage protection? maybe there is a mechanical problem with the board in the connector area?
    I'm doing some more tests, then i'll let you know!
    in the meanwhile thanks again
  • mon2
    replied
    OMG.
  • vannix
    replied
    i am pretty sure of the welding of the spare part. i do this very often and rarely have problems. the only doubts are about the origin of the chips (it happened to me that chips from china were fake).
    it could be a problem with the ITE chip, but not with the firmware because the board works with the battery
    however i cutted the trace between the charger and the voltage divider and there is another strange situation.. 0v on the charger side, but also 0,754v on the voltage divider side, so the problem is in the charger, but also in the EC?
  • mon2
    replied
    Based on the posted measurements, believe that the charger IC is pulling this line down.
    I know that this part has been replaced a few times. Are you confident on the reflowing of the replacement part ? Lots of flux & heat but low air pressure to make the component sink onto the pads.
    Personally do not have experience with the ITE controller so not sure if it has blown out its firmware - welcome comments from others. That is, if there is firmware on this EC controller, can this GPIO pin become an output and pull down this voltage divider rail ??
    Do not think so at this time as the default of GPIO pins is an input mode and the rail does not look to be shorted (from the diode reading).
    So this leads to the charger IC driving this pin low due to some fault or voltage not reaching the charger IC pins.
    Perhaps, gently consider to reflow the IC and test again. Only if you feel comfortable, consider to find a sweet spot to cut the trace from the IC to the voltage divider resistors. Then for sure we will know who is pulling down this line.
    A slight cut with the tip of an x-acto knife blade should do it. The more difficult task is to restore the same cut trace. Scrape the green solder mask to expose the cut trace for soldering with a piece of wire.
  • vannix
    replied
    No - wait - no cutting of traces and do not inject voltage, yet. So they must be using a direct PCB trace for the PR30 location on the PCB.
    Something is pulling this voltage divider rail to 0v - it could be the charger IC but it will do so if the conditions of ACOK are not met.
    Or another external factor. The ACIN trace enters the ITE chip and each mode of this pin is an INPUT style of port pin. Unless the ITE chip is defective, it will not pull down this signal rail.
    Confirm that ACDET voltage is reaching the charger IC @ pin # 6. Carefully measure directly on the charger IC to confirm the chip is able to read this voltage.
    Then remove all power. Wait a minute to allow for discharge of the caps.
    Then meter in DIODE mode.
    Red meter lead to GROUND.
    Black meter lead on point #2 = between the 2 resistors (PR39 & PR40).
    What is the reading in DIODE mode ?
    ACDET reach the ic (2,649v on pin6)
    in diode mode it measure 0,502v
  • mon2
    replied
  • vannix
    replied
    Ok. Good.
    There is a resistor or solder blob between point #2 and point #3.
    Remove this part (pr30) or short.
    Then check the voltage again without this resistor.
    Measure at point #2 with dc adapter only.
    I already check but unfortunately there is nothing to remove. I should cut the track with a cutter but it is very small and the board has many layers, i think i'll damage the 2nd layer
    you can see the picture in the post 5: https://www.badcaps.net/forum/showpo...26&postcount=5
    (pr39/40 are the 2 black resistor without the value label in the first photo, opposite side of 24780)
    if you think it's safe i can inject 2 or 3v in point #2 to check the voltage divider
  • mon2
    replied
    Ok. Good.
  • vannix
    replied
    the resistors (soldered on pcb) measure:
    PR39 85,9k
    PR40 86,2K
    point 2 to ground is 86,2k (the same as pr40)
  • mon2
    replied
    Remove all power.
    Meter in resistance mode (higher than 100k scale).
    Check the resistance with probes on point #1 and #2.
    We want to check the resistance of this resistor.
    Next, check the resistance to ground of point #2 and ground.
    Post the measurements. No power for each test.
  • vannix
    replied
    1: 5,94v
    2: 0,00v (0,0021)
    3: 0,00v (0,0021)
    i also tried another (new) 24780s with same identical result
    ACOK from datasheet says:
    Active HIGH AC adapter detection open drain output. It is pulled HIGH to external pullup supply rail by external
    pullup resistor when a valid adapter is present (ACDET above 2.4 V, VCC above UVLO but below ACOV and
    VCC above BAT). If any of the above conditions is not valid, ACOK is pulled LOW by internal MOSFET. Connect
    a 10-kΩ pullup resistor from ACOK to the pullup supply rail.
    but all conditions seems valid
    is a hopeless repair
  • mon2
    replied
    1) ACOK is not OK. Under the posted measurements and as documented in the TI datasheet, pin # 5 should be HIGH. However, this is an open-drain pin so the logic high really means the pin will be 'floating' like an open switch.
    For this reason, an external resistor must be used for the 'pull-up to a soft high' and this resistor is @ PR39.
    2) See attached. Confirm the voltage measurements with the adapter connected on the requested points of interest @ 1, 2 and 3.
    PR39 is pulled high using the LDO regulator pin # 24 = ~6 volts.
    So this same voltage should appear on one side of PR39.
    Noting that the ~6 volts is too high for logic ICs, TI is using a resistor based voltage divider with the PR39 and PR40 resistors.
    Each is the same value (or should be). So the output voltage (between the 2 resistors) should be 50% of the ~6 volts and be presented onto ACOK rail.
    Confirm the measurements of each.
  • vannix
    replied
    Pq1 bq24780s voltages:
    Pin 1 : 0,00
    Pin 2 : 0,00
    Pin 3 : 0,05
    Pin 4 : 0,35
    Pin 5 : 0,00
    Pin 6 : 2,65
    Pin 7 : 0,20
    Pin 8 : 0,00
    Pin 9 : 0,00
    Pin 10 : 0,00
    Pin 11 : 0,25
    Pin 12 : 0,06
    Pin 13 : 0,00
    Pin 14 : 3,13
    Pin 15 : 0,02
    Pin 16 : 0,00
    Pin 17 : 0,22
    Pin 18 : 0,25
    Pin 19 : 0,22
    Pin 20 : 0,22
    Pin 21 : 0,00
    Pin 22 : 0,00
    Pin 23 : 0,00
    Pin 24 : 5,94
    Pin 25 : 5,61
    Pin 26 : 0,22
    Pin 27 : 0,22
    Pin 28 : 19,45
  • mon2
    replied
    Measure the voltage on each pin of the charger IC using only the external dc adapter (no battery). Do this carefully to avoid damage from slipping of the meter probes.
    Post each measurement.
  • EazyBone
    Onn 100044717 Black screen 75 *Solved
    by EazyBone
    Got this ONN 100044717 75 inch TV which shows a black screen when turned on. In a dim room or if you take a flashlight too it you will still see a picture. TV has sound also.
    The defect is the power board capacitor near the backlight connection. It is the same defect. Look for a bulged cap. Read this thread for more info as it's same defect.
    https://www.badcaps.net/forum/troubl...solved-70-inch
    03-31-2025, 12:23 PM
  • Andreasbest
    [Solved] Fujitsu Lifebook E558 USB / HDMI / DisplayPort / LAN / 3.5" jack dead
    by Andreasbest
    Hello.
    I just solved a mystery with the right USB or HDMI/Displayport or Ethernet or 3.5" jack of Fujitsu Lifebook E558 going suddenly dead.
    I realized i had 6 pieces of the same model with the exact same issue, nothing on google, neither schematics so i had to dig in my self and provide feedback here in case someone else has the same issue.
    I found out that the USB daughterboard is connected to the mainboard with 2 wide and non bending flex tapes that are 2mm longer than they should and this results in a constant pressure on flex connector and therefore eventually it cracks...
    11-26-2024, 11:50 AM
  • Curious808
    Brother HL-2140 laser printer: printer error (solved)
    by Curious808
    SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
    Windows 10
    Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
    Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
    06-22-2023, 11:11 PM
  • im_trying
    Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
    by im_trying
    Laptop does not power on but has a fix white light on power button, when connected to power.
    I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
    The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
    To my fingers, nothing seems...
    05-08-2025, 12:01 PM
  • 247it
    [SOLVED] Lenovo E15 G4 charging at 5 volts
    by 247it
    Hi everyone, I hope someone has some pointers for me, for fun I'm trying to repair USB C charging on a Lenovo E15 G4 laptop, I brought this back from work as it was written off, I successfully replaced the USB C port some time ago, however it was broken again by the end user, this time the port was twisted off the board but the pads survived,
    I have installed another port but the charger never gets the ok from the PD chip (tps65994ae) to go to 20 volts, it does charge slowly using the boost converter to step up the charging voltage but takes hours, voltages present on the PD controller are...
    03-05-2025, 05:21 AM
