Dell p89f Selek MLK AMD 19802-1
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Please help
    The above system with the board number: 19802-1 powers on, capslock light came on, the screen lights up but no image on the screen.
    Please, walk me through on how to resolve this fault.
    The full inscription is: selek MLK AMD 19802-1 FGRDN$LA
    • 20884
    Re: Dell p89f
    Originally posted by Zilicon
    Please help
    https://www.badcaps.net/forum/showthread.php?t=88758
    Here we will give just a few pointers to what kind of troubleshooting has to be done if you suspect a board issue.
    Powers on but no display[LIST][*]Check if it's no backlight, no image or both
    • If no image:
      • Check if external display works, try with internal LCD disconnected as well.
      • Measure voltage on LCD power rail(s)
    • If no backlight but image is present
      • Try to locate the fuse (or resistor or inductor) to backlight rail and check if it's blown
      • Measure voltage on backlight rail, backlight enable signal, brightness adjustment signal
    [*]Check if laptop is POSTing: pressing caps lock key triggers caps lock LED, activity of USB drive blinks when turning on, audio plays, HDD is being read, etc… If it's not POSTing:
    • Check RAM compatibility
    • Reseat RAM and clean RAM slots
    • Measure exact voltage on CPU VCore
    • Check CPU Reset signal
    • Follow power sequence if it exists in the schematics
    • Follow list of power rails if it exists in the schematics
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      Re: Dell p89f
      • If no image:
      Thank you @smdflea
      • Chaminda4191
        Chaminda4191
        • Apr 2023
        • 24
        • Sri Lanka
        you can disable the discrete VGA. To do this, remove the following inductors: PL8601, PL8503, PL8504, PL8501, PL8506, PL8505, PL8507, PL8503. Removing these will enable the UMA mode.
        • andrhouseolly
          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
          by andrhouseolly
          Hi.
          I kindly ask you to help me solve the problem.
          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
          The board turns on, there is no image.
          Read more. When the power supply is connected, the front panel indicators light up briefly.
          When you press the power button, the button indicator lights up. The board works
          there is no image, there is no matrix initialization, there is no image on HDMI.
          When turned on, the fans do not spin, but when they warm up they start spinning.
          When you turn off the button, the fans spin up to full speed for a short...
          05-11-2024, 03:14 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • huzo
          Dell 5590 no image on LCD,HDMI works ,the board works...
          by huzo
          The board is LA-F411P ,DELL 5590 ...
          The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
          02-16-2025, 03:08 PM
        • juergenb
          Dell Precision 3660 - BIOS Image, Hidden Settings, Thermal Settings ?
          by juergenb
          I got my self a new Dell Workstation (Dell Precision 3660, i5-13500).
          Unfortunately, Dell has fixed the front fan´s settings in the BIOS.
          Both the speed and the presence of the fan are fixed.
          There seems to be no hidden setting.
          The thermal tables for the speeds were changed in one of the last BIOS updates.
          Do you see a possibility to change these tables from the BIOS update file?
          Precision_3660_2.1.0 -> Release Notes
          Updated the thermal table to reduce fan noise.
          Updated Intel Management...
          08-12-2023, 03:50 AM
        • Zilicon
          Dell p89f Selek MLK AMD 19802-1 schematics diagram and boardview request
          by Zilicon
          Please I need the above schematics diagram and boardview.
          The number on the board is: Selek MLK AMD 19802-1
          05-10-2022, 05:19 AM
