samsung tab e slow at charging
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    Hi, I have a samsung tab 4 thats very slow at charging, I have replaced port, cable and used a samsung wall charger and a mains socket charger (240 mains with built in usb port) and replaced the battery with 2 different ones, any ideas?
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: samsung tab e slow at charging
    original charger? fast charge will reduce battery life quicker
    • DiamondTech61
      • Aug 2021
      • 61
      • united kingdom
      its a samsung s10 plus charger with a couple of different cables, i know on some when the wrong charger is used it shows a message saying about slow charging which has the option to not show again, im just thinking has someone maybe disabled that message, im not sure if tab e even had that message as its an old tab
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
        09-07-2024, 05:50 AM
      • dimis1975
        Macbook A1466 2014 not charging with macsafe 2 charger
        by dimis1975
        I have a macboook air a1466 that stopped charging the battery.
        BAT PINS: with or without ADAPTER IN
        1- GND
        2- GND
        3- GND
        4-0V sense pin
        5-3.42V
        6-3.42V
        7- 8.4V
        8- 8.4V
        9- 8.4V
        AC Adapter plugged in: after a lot of of hours some times start charging
        No BAT Connected- Green to Orange
        AC Adapter plugged in: BAT Connected- no light
        The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
        Any ideas what’s wrong please?...
        08-05-2025, 03:43 AM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
