samsung tab e slow at charging
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    Hi, I have a samsung tab 4 thats very slow at charging, I have replaced port, cable and used a samsung wall charger and a mains socket charger (240 mains with built in usb port) and replaced the battery with 2 different ones, any ideas?
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: samsung tab e slow at charging
    original charger? fast charge will reduce battery life quicker
    • DiamondTech61
      • Aug 2021
      • 61
      • united kingdom
      its a samsung s10 plus charger with a couple of different cables, i know on some when the wrong charger is used it shows a message saying about slow charging which has the option to not show again, im just thinking has someone maybe disabled that message, im not sure if tab e even had that message as its an old tab
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
        09-07-2024, 05:50 AM
      • pc_okay
        FX516PR not charging on DC charger (but charging on Type-C)
        by pc_okay
        Hello friends,
        I have this board not charging with charger, working fine on battery and type-C charger.
        Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
        I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
        Am I right?
        Links for shematics and boardview: https://www.badcaps.net/forum/troubl...aptops-tablets...
        10-02-2024, 06:16 AM
        09-06-2024, 11:40 PM
