a1989 5V 0,25A
  • firebroker
    • May 2022
    • 8
    a1989 5V 0,25A
    Hello, I am trying to repair my MacBook 820-00850 after small water damage. here are some facts:
    USB-C port burned pin
    liquid damaged pin on power button connector (
    all ports stuck at 5V 0,25A, I can enter DFU (than 20V present and 0A), restore revive not working
    I am missing all SSD power rail and enable signal SSD0_VR_P2V7_EN from U9000 too
    L9080- diode reading is 0,4
    L9080- right after unplugging charger is 0,078 and slowly rising to 0,4 (is it normal?)
    can you advise me please ? thank you
  • mon2
    • 14675
    Re: a1989 5V 0,25A
    Check diode mode to ground of the LDO rails of all CD3215 chips. Post the readings.
    Meter in diode mode.
    Red lead (yes red) to ground.
    Black meter lead to ldo rail to test.
    Diode readings should be done after enough time is given to discharge the logic board.
    • firebroker
      • May 2022
      • 8
      Re: a1989 5V 0,25A
      thank you for your fast replay and time.
      readings: pin 2, 35, 53, 75
      U3100
      0,493
      0,527
      0,515
      0,534
      U3200
      0,497
      0,529
      0,517
      0,535
      UB300
      0,498
      0,530
      0,518
      0,537
      UB400
      0,496
      0,529
      0,518
      0,534
      PPBUS_G3H - 12,29V
      • mon2
        • 14675
        Re: a1989 5V 0,25A
        Diode readings look ok.
        PPBUS_G3H - 12,29V
        https://www.logi.wiki/index.php?title=PPBus_G3H
        This voltage is low and should be 12v6 after communication with the SMC.
        Measure the voltage readings of:
        I2C_PWR_SDA
        I2C_PWR_SCL
        which are level shifted I2C bus lines used by U7000 for communication.
        Also measure the voltage readings of:
        SMBUS_3V3_BATT_SCL
        SMBUS_3V3_BATT_SDA
        to confirm the status of D6950 (battery ESD transient protection device).
        Meter in DC volts mode (anything 5 volts or higher is ok for these tests).
        Black meter probe to ground (shield is ok).
        Red meter probe to the point to test.
        Post your readings.
        • firebroker
          • May 2022
          • 8
          Re: a1989 5V 0,25A
          I2C_PWR_SDA 1,79V
          I2C_PWR_SCL 1,79V
          SMBUS_3V3_BATT_SCL 3,36V
          SMBUS_3V3_BATT_SDA 3,36V
          Battery voltage is 0V
          PPVBAT_G3H_CONN 12,6V after 4seconds 0,2V, after 4seconds 12,6V.. cycling
          and see what happens
          I have checked charger meter and suddenly 20V there and board started to boot. I assembled the whole machine back. I don't know what happened, but at the time of writing this post, MacBook started working... a miracle
          Yesterday I did a reflow of U9000 and U9080 and did not help. I wrote here on Badcaps, did some measurement together and the board started to work now
          Thank you very much for your time and help, If I can donate/support you, let me know please
          • firebroker
            • May 2022
            • 8
            Re: a1989 5V 0,25A
            And today the same problem appeard after nearly 10 days of active usage of macbook.
            After few hours of youtube watching I wanted to charge a macbook and nothing happened.
            20V 0A. Restart did not help, and then my battery went to 0% and is dead again
            I am stuck at 5V 0,25A
            SMBUS present, I2C present
            any ideas for help ?
            thank you
            • mon2
              • 14675
              Re: a1989 5V 0,25A
              What is the voltage of PPBUS_G3H ?
              • firebroker
                • May 2022
                • 8
                Re: a1989 5V 0,25A
                Ppbus_g3h 12,29v
                • mon2
                  • 14675
                  Re: a1989 5V 0,25A
                  Review the diode readings of each LDO rail of the CD3215 as per post #2.
                  Remove all power. Meter in diode mode to measure.
                  One of the causes of being stuck @ 5V is that a CD3215 has failed.
                  • firebroker
                    • May 2022
                    • 8
                    Re: a1989 5V 0,25A
                    it is still the same readings :/
                    • bastien
                      OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                      by bastien
                      It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                      This is the new database for FlexBV
                      it's optimized to work with it
                      by using board ID has Default name, give us the opportunity,
                      to use other diode board data with sibling board or family board
                      I Merged the whole data (optimal)
                      A2991 A2992 M3 -> -> 2 Entries diode data M1
                      A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                      A2442 A2485 A2779...
                      03-18-2025, 08:03 AM
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • PITERPENY
                      Macbook A1989, 820-00850, won't boot. 20V, 0A.
                      by PITERPENY
                      Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                      Here are some measurements, maybe someone can tell what the problem is.
                      The initial problem was a burnt out induction coil L8504 (replaced).
                      When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                      here are some measurementsmotherboard...
                      01-16-2024, 02:19 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • Baste
                      MBR3045CT and SR3045LCT Schottky diode testing help.
                      by Baste
                      Hello experts,
                      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                      Aneng ST182 Meter.
                      Diode mode.
                      MBR3045CT:
                      Diode mode
                      Pin 2-1 - 0.150v
                      Pin 2-3 - 0.150v ...
                      10-21-2025, 06:14 AM
