Lenovo Ideapad C340-15IIL intermittent charging
  • REpairAT
    • Nov 2020
    • 143
    • Austria
    I had this case on at least 4 or 5 times different Lenovo Models already, never found a solution. Right now it's a Lenovo Ideapad C340-15IIL with a new OEM Battery. Also, I've got a used, but confirmed working OEM battery from a similar model.
    Symptoms are always the same:
    -> Charger disconnects almost all 2 seconds
    -> Computer always switches between AC / Battery mode
    -> Computer is fully functional in either battery OR AC mode with battery disconnected
    -> Orange charging LED blinking all the time
    -> Also when computer is turned off, the battery state splash screen appears all the time.
    -> Leaving it plugged in and turned off, battery will fully charge after some time, yet symptoms from above don't change.
    -> If I disconnect the battery with plugged in charger in a moment it says "on battery", the computer immediately turns off, so obviously the main power rail is disconnected by primary mosfet.
    The laptop is in mint condition, never opened before, no liquid damage etc.
    New OEM Charger and other OEM Battery did not solve the issue.
    Charger voltage does not increase or change whenever it switches from AC to battery mode.
    I assume it's a LENOVO problem, not an issue with this particular model. Does anyone have any experience with this?
    Thanks a lot!
    BR, Ray
  • mon2
    • 14659
    Re: Lenovo Ideapad C340-15IIL intermittent charging
    Hi.
    1) link any schematics if on this forum.
    2) which battery charger IC is onboard?
    3) with all power removed, no battery, meter in resistance mode. Check the resistance of each mosfet for possible damage.
    Post the markings on the top side of each mosfet linked to the charger IC.
    • REpairAT
      • Nov 2020
      • 143
      • Austria
      Charging IC is Intersil 88739A. Behaviour now is that it shuts down the first two mosfets after about 30 seconds of charging completely. Both mostfets are ok. I can't find any schematics neither from the laptop, nor from the charging IC
      • mon2
        • 14659
        How many pins on the ISL88739A ? 28 pin QFN package ?
        NVM, found the short datasheet= 32 pin QFN
        • mon2
          • 14659
          Ok. Reverse engineer / hack it. It should be straight forward.
          Meter in resistance mode (lowest scale). Remove all power.
          1) Start with the battery connector.
          2) The +volts connection on the battery pack will be ganged together to allow for a heavier current flow. Locate these pins.
          The resistance between the pins should be ~0 ohms.
          Now this group MAY be GROUND so check for it to confirm. One meter probe to the '+volts' cluster and other probe to shield ground on your logic board.
          If there is NO connection (O.L.) then continue to locate the GROUND cluster. Once it is found, you know the original group = +volts.
          3) Now place meter probe on this cluster and the other side to the closest inductor on the logic board = Battery charging leg of the circuit.
          4) Next you should see a large arse current sense resistor which will be a very low resistance, by design. Very concerned about this leg.
          Trace the one side of this resistor to the ISL mystery IC and record the pin #.
          The NEXT pin on the ISL IC = should be the OTHER side of the current sense resistor. Record the pin #.
          Interested to know the resistance from the current sense resistor legs back to the ISL device.
          It is very possible and common that the lack of the current sense resistor feedback to the charger IC will halt the charging.
          Just a thought but must be validated either way.
          You can perhaps print out a random IC with 32 pin QFN package -> call it your ISL device and mark up the voltage pins as you go.
          Confident that ISL has this device in the witness protection program (much like some of the techs here that once they have their fix, they vanish!!). Till next time.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Use Acer LA-H501P schematic to troubleshoot Charging IC. It uses the same ISL88739A. Schematic is available on this forum. Use search to locate it.
              NVDC charger configuration...
              11-05-2024, 03:28 PM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
            • ferah831208
              by ferah831208
              03-18-2025, 01:18 AM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
