Need help with hp 840 g1
  • amr soliman
    • Oct 2015
    • 123
    • egypt
    I have hp 840 g1 with a few tea drops on main board after cleaning it was working perfectly but after one day it start to power down after logo start some time it continue tell windows password then sleep if power button pressed screen comes and went sleep again
  • amr soliman
    • Oct 2015
    • 123
    • egypt
    Re: Need help with hp 840 g1
    any help here
    • mon2
      • 14667
      After the unit goes to sleep, can you see anything on the LCD with a flashlight?
      Is the unit really asleep or just the display goes dark ?
      • amr soliman
        • Oct 2015
        • 123
        • egypt
        look it most time shut down when logo start
        but when its working it goes to sleep
        • mon2
          • 14667
          Is this the HP or Windows operating system logo ?
          If HP, that is the first power on logo ? Try different RAM on the logic board and see this fixes the issue.
          If it is Windows logo, remove the SSD / HD and see if the system boots up everytime for the BIOS setup. Do this 5-10 times to confirm.
          Any issues with the keyboard / keys being stuck ?
          • amr soliman
            • Oct 2015
            • 123
            • egypt
            its hp logo and i trye another ram and witout hdd and keyboard even without screen
            • mon2
              • 14667
              Are there schematics for this logic board ?
              What are the markings on the white silk screen on the board ? You can post pics for a review.
              Suggestions are:
              Remove all power. No battery. Meter in resistance mode. Check the resistance to ground of each coil (likely grey in color). Checking for any very low resistance readings.
              • amr soliman
                • Oct 2015
                • 123
                • egypt
                after replacing smsc sio its working but gave fan error and shutdown
                • cappernicus
                  Satellite r945-p440 - Hard crash coming out of sleep
                  by cappernicus
                  Toshiba Satellite r945-p440
                  Motherboard: FAM2SY2 A3256A
                  I do not have a schematic or board file
                  I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
                  04-16-2025, 05:31 PM
                • survivalbloke
                  Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
                  by survivalbloke
                  This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
                  03-20-2025, 02:29 PM
                  Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                  This is a new item at Electronic GoldMine that has arrived within the last few weeks
                  Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                  Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                  https://theelectronicgoldmine.com/products/g28392
                  One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                  11-24-2024, 01:25 AM
                • rumi409
                  LG OLED C1 Pixel Cleaning Made Picture Worse
                  by rumi409
                  ​​​​​​ Hi,
                  I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                  11-15-2024, 01:09 AM
                • Thermaltake
                  HP 450 G1 Boot ask F1 continue F10 bios
                  by Thermaltake
                  Hi, I got HP 450 G1 with boot problem always asking F1 continue F10 bios. I had bad battery on it and replace it with new one because it was giving me error 601. I was thinking that this F1 continue F10 BIOS has to do something with my bad battery, but when I replace it I was not having error 601 anymore but that message on boot with F1 continue F10 BIOS is still here. I tried to replace CMOS battery and reset bios, nothing. I tried to flash new BIOS but it already have latest one and I even tried to overwrite it, still same. Don't know what to do anymore. Does someone have any clue what this...
                  01-13-2024, 09:12 AM
