HP 450 G1 Boot ask F1 continue F10 bios
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    Hi, I got HP 450 G1 with boot problem always asking F1 continue F10 bios. I had bad battery on it and replace it with new one because it was giving me error 601. I was thinking that this F1 continue F10 BIOS has to do something with my bad battery, but when I replace it I was not having error 601 anymore but that message on boot with F1 continue F10 BIOS is still here. I tried to replace CMOS battery and reset bios, nothing. I tried to flash new BIOS but it already have latest one and I even tried to overwrite it, still same. Don't know what to do anymore. Does someone have any clue what this could be ?
  • mon2
    • 14861
    https://www.computerhope.com/issues/...C%20and%20exit.
    Go to your BIOS and select to load factory defaults -> save and exit. Does that work?
    If you do select F1, does the unit continue to boot normally?
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 337
      • D12
      Did that too, doesn't help. When I select F1 it boots to windows normally.
      • mon2
        • 14861
        Go into the BIOS and save changes (even though nothing has changed) -> reboot.
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 337
          • D12
          Did that too, still asking. But I noticed if I don't touch anything for 4-5 seconds it starts too boot into windows.
          • mon2
            • 14861
            Check to see if you have an option in the bios for a FAST BOOT. Enable it if you do. Save and exit to retest.
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 337
              • D12
              It's enabled, same thing.
              • mon2
                • 14861
                Review the first answer here - perhaps the same as yours.
                https://community.hpe.com/t5/prolian...p/td-p/4979272
                You can disable "F1" from the advanced options in the system configuration utility. Press "F10" during POST process;
                when you see screen "System Configuration" press CTRL+A - you will have message like "advanced mode has now been enabled"
                Go to System Configuration->Configure hardware-> Review or modify hardware settings->View or edit Details-> under advanced features there is F1 boot prompt option.
                • Thermaltake
                  Brain badcap
                  • Aug 2015
                  • 337
                  • D12
                  Not the same error. This user have problem with proliant, that's server. When I press F10(which is like I wrote beside that F1 options that pops on boot) laptop goes into BIOS, laptops and servers have two very very different BIOS from one another, and laptops don't have that option for CTRL+A to go in advanced mode.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 337
                    • D12
                    Found a problem.
                    Shorting touchpad, to be exact part where buttons are that electronic was bad and touchpad was not working for some reason. Now I replaced it with new one and it's working, and more F1 and F10 message.
                    • kenkaniff
                      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                      by kenkaniff
                      Product Name: HP Pro x360 Fortis 11-inch G9
                      System BIOS: U94 Ver.01.08.00 10/06/2023
                      Serial Number: 5CG31946F5
                      SKU Number: 85W05EC#AK8
                      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                      I needed to remove bios password...
                      10-01-2025, 04:32 AM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • q2v5
                      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                      by q2v5
                      Lenovo T480s
                      Model 20L8-S3TE00
                      Board ET481-U10
                      Chip MX25L12873F
                      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                      08-15-2024, 10:40 PM
                    • Neddsme
                      Bios partially corrupted somehow and now warm boot doesn't work which is critical
                      by Neddsme
                      Hie.
                      I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                      Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                      I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                      I managed to run Windows troubleshooting and...
                      02-04-2022, 05:57 AM
                    • Max029
                      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                      by Max029
                      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                      TY,
                      08-18-2024, 08:28 PM
