Does someone know if I can build in a Macbook Pro M1 logicboard to an Macbook Air M1 chassi?
Macbook Pro M1 logicboard to an Macbook Air M1 chassis?
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by felix27Hello,
I want to fix a 2016 12 Inch Macbook which has a dead Logic Board.
USB-C and Battery section seems to work, trackpad clicks, but all cpu Voltages, (VCORE, CPUSA) are 0V, CPU stays cold.
PPBUS_G3H, 3.3V and 5V Rails seem normal. PM_SLP_S3_L is present but CPU_VR_READY is not.
Thanks for your help! -
by shlomim412Hello
working on a2141 macbook, board number 820-01700 which has no wifi\bt and also no connection with LAN cable.
initial visual inspection the board looks good no visible corrosion or damage.
i found that PP3V3_G3S_X is shorted to ground (around 1.5ohm short)
and also PP3V3_GS3_WLAN i shorted to ground (same ohm reading, around 1.5ohm).
the board is working but no WIFI\BT as i mentioned.
with the usb c cable connected for measurement i noticed U8215 i getting EXTREMELY HOT
so i pulled it out figuring it might be causing the... - Loading...
