a1466 820-00165 no power
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    I have green light become orange in a sec .
    Voltage reading :
    PM_slp_s4 0v
    PPVRTC_g3H 3.3
    PPBUS_g3h 8.6
    ppbus_s5_hs_computing_isns 8.5
    PP3v42_g3H 3.4
    PP5v_s5 5v
    PP3v3_s5 3.3
    PP3v3_SUS 0v
    P3V3SUS_EN 0v
    PP1V05_sus 0v
    RTC_RESET_L 3,3
    PCH_SRTCRSTL 3.3
    PM_DSW_PWRGD (DPWROK) 0v
    PM_BAT_LOW 3.3
    PM_RSMSRT_L 0v
    PM_PWR_BTN_L
    PM_SLP_SUS_L 0v
    S5_PWRGD 3.3
    PCH_DSWVRMEN 3.2
    PM_DSW_PWRGD 0v
    SMC_ADAPTER_EN 3.3
    PCH_INTRUDER_L = 3.2
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: a1466 820-00165 no power
    • mon2
      • Dec 2019
      • 14105
      Review this:
      https://www.it-tech.com.au/mac-q-a/p...2ZQcVlaYV9LUGc.
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        What could it be ? r8141 measures 100k
        • mon2
          • Dec 2019
          • 14105
          check the voltage on each side of r8141.
          Do you see +3v42 on r8141, pin # 1 ? This is an open-drain output and the r8141 pull-up resistor is required to pull up this line to a '1' state.
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            pin 1 3.40
            pin 2 3.36
            • reformatt
              • Feb 2020
              • 1404
              Check board thoroughly for corrosion and each sub-rail for shorts/low impedance (especially PCH). Also check PM_SLP_S4 state when initially connecting magsafe (no battery). If you don't get any activity, then review the PM_SLP_S4 pre-requisites. If you get a pulse (once or twice) problem is elsewhere.
              • lordgeny
                • Apr 2016
                • 223
                • Italia
                the multimeter goes from 0.25mv to 50mv as soon as I connect the power supply
                • mon2
                  • Dec 2019
                  • 14105
                  What is the voltage of PPDCIN_G3H after you connect the original power supply ?
                  Also measure and post the readings of:
                  PPVIN_G3H_P3V42G3H
                  PP3V42_G3H
                  F7140, pin #1
                  F7140, pin # 2
                  • lordgeny
                    • Apr 2016
                    • 223
                    • Italia
                    PPVIN_G3H_ 16.8 0.680
                    P3V42G3H 3.40 0.280
                    F7140, pin #1 8.60 0.140
                    F7140, pin # 2 8.60 0.140
                    • lordgeny
                      • Apr 2016
                      • 223
                      • Italia
                      PP5V_S4RS3 not present
                      • mon2
                        • Dec 2019
                        • 14105
                        Review this thread:
                        https://boards.rossmanngroup.com/thr...v_s4rs3.59197/
                        • lordgeny
                          • Apr 2016
                          • 223
                          • Italia
                          P5VS4RS3_EN not present
                          P3V3SUS_EN not present
                          • mon2
                            • Dec 2019
                            • 14105
                            Post the voltage readings for:
                            S4_PWR_EN
                            PM_SLP_S4_L
                            • lordgeny
                              • Apr 2016
                              • 223
                              • Italia
                              0v both
                              • mon2
                                • Dec 2019
                                • 14105
                                Post the voltage readings of R1460, pin # 1 and also of pin # 2.
                                Then remove all power -> meter in resistance mode (100k or higher scale).
                                Measure the resistance across R1460.
                                • piernov
                                  • Jan 2016
                                  • 4435
                                  • France
                                  No point in checking random things, must fix things in order of the power sequence…
                                  • reformatt
                                    • Feb 2020
                                    • 1404
                                    Piernov is 100% correct. The power sequence is available here:
                                    https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
                                    From the first post:
                                    S5_PWRGD=3.3 yet PM_DSW_PWRGD=0V
                                    Piernov alludes to this in his first post, however I guess this wasn't clear to the OP. You won't get to S4 beyond this signal, so troubleshooting beyond PM_SLP_SUS_L is a waste of time.
                                    PM_DSW_PWRGD comes from the SMC, so you need to be troubleshooting why this is low. Check all supplies around the SMC (PP3V3_S5_SMC_VDDA, PP3V3_S5_AVREF_SMC etc), also check for signs off liquid damage in this area. Sometimes you get crap under the SMC causing weird issues, so I remove the edge bonding and reflow it with flux. Could also be a crook SMC of course too.
                                    • psdavid65
                                      A1466 820-3437-B Bios Problem
                                      by psdavid65
                                      I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
                                      06-18-2024, 05:26 AM
                                    • Sergio Kub
                                      MAcbook Air A1466 EMC 3178 - 2017 Boot
                                      by Sergio Kub
                                      Could someone help me?
                                      I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
                                      Could it be the BIOS?
                                      07-08-2025, 04:41 PM
                                    • Sergio Kub
                                      Macbook Air A1466 EMC 3178 - 2017 Boot
                                      by Sergio Kub
                                      07-08-2025, 04:12 PM
                                    • dbuergi
                                      Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                                      by dbuergi
                                      i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                                      So for unsoldering my spare parts and soldering back i would ask for some advises.
                                      On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                                      I have a small USB heating plate and a Atten ST-862D with several nozles.
                                      06-27-2025, 02:59 AM
                                    • myth77
                                      A1369 and A1466 top case housing the same?
                                      by myth77
                                      I didnt know where to ask (on what topic) but does anyone know can i use macbook air A1369 TOP CASE (with or without palmrest and keyboard) on A1466? they look the same but i am not sure. On aliexpress they sell them as same but on some places they sell only a1466 for a1466. anybody knows? Maybe the case/housing is the same but keyboard and touchpad different? but if thats the case i would change them..
                                      08-06-2022, 10:06 AM
