ASUS ROG G14 (GA401) battery spark, dead.
Re: ASUS ROG G14 (GA401) battery spark, dead.
VCC on charging IC is 19.7V
ACOK is fed 6V.
Could it be a defective shorted battery? Voltage measures 0V on the battery, but it worked before, so maybe some internal protection got triggered?Last edited by jacobtc; 06-05-2022, 09:25 AM.Comment
Does the logic board function without the battery ? It should.
If it does not, the battery is not a factor. For now, work without the battery.
You can inspect the SMBUS (I2C) lines on the battery connector.
Remove all power. Meter in resistance mode.
Check the resistance to ground of the following:
P_SMB0_CLK - pin 3
P_SMB0_SDA - pin 4
Red meter lead on the pin; black to ground.
What are the resistance readings for each ?Comment
Yes, the board works without the battery connected.Does the logic board function without the battery ? It should.
P_SMB0_CLK - pin 3
P_SMB0_SDA - pin 4
Should I measure resistance on the battery, when it is not connected to the board, or on the terminals on the board, when the battery is connected?
Also, the connector does not seem to have a P_SMB0_SDA pin, only a CLK and DAT pin, see pic.Last edited by jacobtc; 06-05-2022, 10:49 AM.Comment
See attached.
Post the voltage readings for each point of interest on the battery charge mosfets.
Attach the external power adapter & battery.
Meter in 20V scale. Red meter lead to point to test; Black meter lead to ground.
Yes, it is possible that the battery BMS (battery management system) has shut down due to the spark but others can share their comment on this topic. If you have access to, try a replacement battery for testing.
When the system is booted, does Windows report the presence of the battery ? Battery level ?
The SMBUS / I2C lines seem to be ok with the posted resistance but you can also perform another test.
After the logic board is powered up with the battery -> measure the voltage of the battery connector pins (SCL & SDA) to check if the interface lines are defective or not.
What voltage do you read with respect to ground for the battery connector pins 3 & 4 ?Comment
Here is the readings for the mosfets:See attached.
PQH8901:
D: 20V
S: 0,223V
G: 0,223V
PQL8901:
D: 0,223V
S: 0V
G: 0V
Yes, battery shows up in Windows and bios, and reports as 100% charged.Comment
That is what I am thinking, but before I started diagnosing the machine, I was pretty sure that it was at close to 100% charge, and I didn't leave it in the machine, so having it discharge completely over a couple of months seems unusual.Comment
By the way here is shematic and brdviewComment
I think that the BMS logic inside the battery pack is not communicating properly and resulting in the 100% charge reading.
What is the voltage readings on pins 3 & 4 of the battery connector ?
Have seen cases where these I2C lines are defective and with similar results. If the charger IC believes the charge is full, no work is to be done so turns off the battery linked mosfets.Comment
Both pins are reading 0.06V not connected to the board.I think that the BMS logic inside the battery pack is not communicating properly and resulting in the 100% charge reading.
by jacobtcHi!
It seems like all the laptops I get are dead G14's. I already had two, in which one was fixable, and one wasn't. This one is different though, I promise!
The previous owner used it without a screen, as the panel was dead, and suddenly it just died.
The board looks fine, no visually burnt components as I can see.
I do not get a short on the DC-In mosfets, however as I had with one of my other machines, the first mosfet does not seem to let voltage through, so the second mosfet does not receive 20V. (See pic).
Only the BQ chip... -
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
