ASUS ROG G14 (GA401) battery spark, dead.
Re: ASUS ROG G14 (GA401) battery spark, dead.
Removed the mosfet, and all shorts are now gone
The mosfet is shorted yes, do I still need to replace all mosfets?Comment
Is it due to them having taken damage? It is around 10 mosfets I need to replace then. I resoldered the BQ chip, but I can replace that as well, just more IC's to buy from China I guess...Last edited by jacobtc; 04-29-2022, 09:20 AM.Comment
Yes local electronic store , aliexpress , or ebay i order also i have no shop or tax number so i am obligied to buy in such store, if you got a tax number you can buy by farnell, tme , digikey and etc. Awesome we could find the cultprit of the problem of your laptop. I am sure for 98 procent if you replace the components the laptop will work, good jobComment
All thanks to you, would not have figured out this myself! When I come by Belgium, I'm getting you a beer!Yes local electronic store , aliexpress , or ebay i order also i have no shop or tax number so i am obligied to buy in such store, if you got a tax number you can buy by farnell, tme , digikey and etc. Awesome we could find the cultprit of the problem of your laptop. I am sure for 98 procent if you replace the components the laptop will work, good job ��
If your equipment works, then don't upgrade, I worked in the electrical industry for a couple years, so my Fluke is leftover when upgrading etc.Comment
UPDATE!
Got the mosfets and BQ chip all soldered on, not shorts on the board afterwards.
Thought I was good, and assembled everything, plugged in the charger, and now nothing works, no lights, start button does nothing, charging indicator not showing, completely dead, machine wont start and USB charging also does nothing...
Double checked connections, and they are fine, disassembled the machine again, and did new measurements, can anyone help again?
Still no shorts on board, nothing gets warm when plugged in.
Mystery of the day, no battery is connected, I guess they must be in parallel with the input?
EDIT: The second mosfet at the input outputs 4.2vLast edited by jacobtc; 05-20-2022, 10:49 AM.Comment
Are you confident that the mosfets were mounted with pin #1 = pin # 1 on the PCB ?
Remove all power. Meter in resistance mode.
Check the resistance with the meter probe on pin # 8 and # 7 = should be ~0 ohms.
Then pin # 8 and pin #5 ? Reading ?
Then 1-2-3 = should be ~0 ohms.
What is the resistance between pin 1-2-3 (source) and pin # 4 (gate) ? - if this is ~0 ohms then the mosfet has been soldered upside down.Comment
Thanks, when you say pin #8 and #5, which do you mean? I did not touch the mosfets at the DC in, only down at the charging IC area.Are you confident that the mosfets were mounted with pin #1 = pin # 1 on the PCB ?
Ok. Then remove all power and check the resistance of the DC IN mosfets.
Meter in resistance mode (2k scale is ok).
Check each mosfet with meter probes across:
Source (1-2-3) & Drain (5-6-7-8)
Source (1-2-3) & gate (4)
Gate (4) & drain (5-6-7-8)
Post each measurement. Repeat for the 2nd mosfet. Checking for a low resistance = defective mosfet.
Also post the markings of each mosfet so we can find their datasheets (or a valid replacement).Comment
Thanks, already purchased replacements for them, as it was easier to get all of them when I was already purchasing the ones at the IC charging area.Ok. Then remove all power and check the resistance of the DC IN mosfets.
The PKCH2BB meassures:
S-D: 2.1 MOhm
S-G: No reading, (not 0 ohm, no reading at all.)
G-D: 5 MOhm
The M3058M meassures:
S-D 3 MOhm
S-G: 4.6 MOhm
G-D: No reading, (not 0 ohm, no reading at all.)Comment
by jacobtcHi!
It seems like all the laptops I get are dead G14's. I already had two, in which one was fixable, and one wasn't. This one is different though, I promise!
The previous owner used it without a screen, as the panel was dead, and suddenly it just died.
The board looks fine, no visually burnt components as I can see.
I do not get a short on the DC-In mosfets, however as I had with one of my other machines, the first mosfet does not seem to let voltage through, so the second mosfet does not receive 20V. (See pic).
Only the BQ chip... -
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
