ASUS ROG G14 (GA401) battery spark, dead.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    #61
    Re: ASUS ROG G14 (GA401) battery spark, dead.
    You can inject on the capacitor from the phase pin
    • jacobtc
      • Apr 2016
      • 274
      • Denmark
      #62
      Originally posted by Stevedb
      Yes you need to get system side of the capacitor which is not connected to ground.
      And how do I find that side, when both sides are shorted to ground?
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        #63
        One side of the cap is shorted to ground, the other is not.
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          #64
          By the way do not power the machine up with missing bq chip.
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            #65
            I wont But still not sure where to inject voltage
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              #66
              You can inject on the current sensor if. He is also shorted. I think so because yousaid the mosfets are shorted to ground and capacitors also.
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                #67
                ? The current sensor? Thought I should inject voltage at the phase pin side of the capacitor?
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  #68
                  On your picture you say everything is shorted the capacitors all squares are shorted you said. So the easiest place is a big capacitor on the side those three orthe current sensor r010 from the battery section the green one not the current sensor from dcin mosfetts to be clear. Those capacitor and source mosfets join all the same pad that i can see on the picture.
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    #69
                    Thanks,
                    How do I identify which side is system side, and ground side on those capacitors when they are shorted?
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      #70
                      Current sensor track will not be ground . Also you can measure the two sides one will be lower value then the other lowest value will be ground, you measure ground black probe ant the other red one to the capacitor.
                      • jacobtc
                        • Apr 2016
                        • 274
                        • Denmark
                        #71
                        Couldn't really measure any difference between left or right side on caps, so I traced the positive input of the battery connector, and connected a cap from that direction.
                        1.2V 2A draw, and nothing gets hot, at least not something that shows up on the thermal cam. Should I increase amperage?
                        Soldered a wire to the cap, so it would be easier to inject with the board flipped.
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          #72
                          Yes you can but 1v please and use thicker wires you must see when you inject voltage the voltage the amerage not get lost in the wires, the amerages the heat so best measure you realy inject 1v on the line.
                          • jacobtc
                            • Apr 2016
                            • 274
                            • Denmark
                            #73
                            Okay, I'll try 1V 3A.
                            • jacobtc
                              • Apr 2016
                              • 274
                              • Denmark
                              #74
                              At 1V 4A this mosfet becomes a little warmer than the rest. And the green R010 resister also gets hot on one side.
                              • Stevedb
                                Stevedb
                                • Feb 2018
                                • 624
                                • Belgium
                                #75
                                Resistor is fine nothing else then the mosfet on the all board. Ok remove the mosfet and see if short is gone.
                                • jacobtc
                                  • Apr 2016
                                  • 274
                                  • Denmark
                                  #76
                                  What I'm wondering is why it only gets to 32C, ambient is 28C... Shouldn't it get hotter with a 4A draw?
                                  • Stevedb
                                    Stevedb
                                    • Feb 2018
                                    • 624
                                    • Belgium
                                    #77
                                    Did you check all the board? Both sides? If nothing getting hot anymore. Probably you raise rhe voltage it will be hotter. But i would remove the mosfet and see the short is gone. You sent 4w power in the board is not zmso much.
                                    • jacobtc
                                      • Apr 2016
                                      • 274
                                      • Denmark
                                      #78
                                      Yeah, checked both sides, the hotspot is coming from the mosfet, the other side has no components in that area.
                                      • Stevedb
                                        Stevedb
                                        • Feb 2018
                                        • 624
                                        • Belgium
                                        #79
                                        Ok removed it
                                        • Stevedb
                                          Stevedb
                                          • Feb 2018
                                          • 624
                                          • Belgium
                                          #80
                                          If the mosfet is shorted then you need to replace all the mosfets high and low side mosfet. This is typical shematic from your chip. So you have an idea what we dealing with
