2019 macbook air A1932 MDM removal
  • blacky0425
    • Feb 2019
    • 9
    • usa
    Looking for some guidance on removing mdm from a macbook air a1932. I purchased off ebay as a water damaged console and repaired it.
    It's running mojave and it is not icloud locked. Am good at soldering and have a cheap spi programmer. Is it just a matter of reading the rom and changing the serial number to any random serial?
    Just looking for some guidance as to not mess up as this will be a gift for my daughter.
    Thanks in advance.
  • blacky0425
    • Feb 2019
    • 9
    • usa
    Re: 2019 macbook air A1932 MDM removal
    Anyone....
    • ahmedmeer
      • Nov 2023
      • 11
      • dubai
      2019 macbook air A1932 MDM removal how posible
      • Jenuk
        • Nov 2021
        • 4
        • Ukraine
        Hello, change SN in T2 rom to nonexistent​
        • yajdeeks
          • Jan 2019
          • 6
          • Poland
          Change sn in t2 rom to non icloud locked.
          • yajdeeks
            • Jan 2019
            • 6
            • Poland
            then make a dfu revive
            • bouch
              unlock macbook air A1932 2019
              by bouch
              hi
              i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
              i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
              i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
              have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
              I need help or information?
              Does anyone have the minat2 activator 1.4 software?
              Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
              Thank yo...
              03-12-2025, 10:14 AM
            • mferna14
              820-01521-A (MacBook Air A1932 2019) stuck on 5V
              by mferna14
              Hi all dear friend., today I am working on 820-01521-A logic board (MacBook Air A1932 2019) stuck on 5V .19 milliamps. The history of this logic board was liquid spill on major components. First gave a good cleanup & both CD3215C00Z were getting very hot, so I replaced both. Now on the 12V coil, there is only 5v present & 3.3V is perfect. In some area like PPVIN_G3H_P3V3G3HRTC , PPBUS_G3H_TPAD etc., 12V is perfect. On the 5v coil .2 volts only. I checked the enable signal on the regulator chip, enable is NOT present. The logic board is very clean, I do not see any signs of spill anymore....
              03-27-2025, 04:52 PM
            • Bogbog
              Macbook Air 2019 A1932 / 820-01521-A No power
              by Bogbog
              I recently acquired a faulty Macbook Air 2019 A1932 with mainboard 820-01521-A.
              Seller claimed that device just stopped working suddenly.
              Device does not boot or give any signal of life other than the white led on mainboard.
              Using cheap multimeter and microscope I went trough list of semi-random diagnostic steps:
              Voltage measurements
              Charger in USBC-B (closer to display) everything disconnected.
              PP20V_USBC_XB_VBUS 20.7v
              PP3V3_UPC_XB_LDO 3.25v
              PP1V8_UPC_XB_LDOA 1.81V
              PP1V8_UPC_XB_LDOD 1.80V...
              02-26-2024, 05:04 AM
            • TimScrawn
              MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
              by TimScrawn
              Hi there,
              This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
              I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
              06-23-2024, 09:41 AM
            • Arshad alam4659
              macbook air a1932 sign out of find my
              by Arshad alam4659
              Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
              04-09-2025, 12:37 AM
