2019 macbook air A1932 MDM removal
  • blacky0425
    • Feb 2019
    • 9
    • usa
    Looking for some guidance on removing mdm from a macbook air a1932. I purchased off ebay as a water damaged console and repaired it.
    It's running mojave and it is not icloud locked. Am good at soldering and have a cheap spi programmer. Is it just a matter of reading the rom and changing the serial number to any random serial?
    Just looking for some guidance as to not mess up as this will be a gift for my daughter.
    Thanks in advance.
  • blacky0425
    • Feb 2019
    • 9
    • usa
    Re: 2019 macbook air A1932 MDM removal
    Anyone....
    • ahmedmeer
      • Nov 2023
      • 13
      • dubai
      2019 macbook air A1932 MDM removal how posible
      • Jenuk
        • Nov 2021
        • Ukraine
        Hello, change SN in T2 rom to nonexistent​
        • yajdeeks
          • Jan 2019
          • 6
          • Poland
          Change sn in t2 rom to non icloud locked.
          • yajdeeks
            • Jan 2019
            • 6
            • Poland
            then make a dfu revive
            • bouch
              unlock macbook air A1932 2019
              by bouch
              hi
              i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
              i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
              i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
              have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
              I need help or information?
              Does anyone have the minat2 activator 1.4 software?
              Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
              Thank yo...
              03-12-2025, 10:14 AM
            • mferna14
              820-01521-A (MacBook Air A1932 2019) stuck on 5V
              by mferna14
              Hi all dear friend., today I am working on 820-01521-A logic board (MacBook Air A1932 2019) stuck on 5V .19 milliamps. The history of this logic board was liquid spill on major components. First gave a good cleanup & both CD3215C00Z were getting very hot, so I replaced both. Now on the 12V coil, there is only 5v present & 3.3V is perfect. In some area like PPVIN_G3H_P3V3G3HRTC , PPBUS_G3H_TPAD etc., 12V is perfect. On the 5v coil .2 volts only. I checked the enable signal on the regulator chip, enable is NOT present. The logic board is very clean, I do not see any signs of spill anymore....
              03-27-2025, 04:52 PM
            • Bogbog
              Macbook Air 2019 A1932 / 820-01521-A No power
              by Bogbog
              I recently acquired a faulty Macbook Air 2019 A1932 with mainboard 820-01521-A.
              Seller claimed that device just stopped working suddenly.
              Device does not boot or give any signal of life other than the white led on mainboard.
              Using cheap multimeter and microscope I went trough list of semi-random diagnostic steps:
              Voltage measurements
              Charger in USBC-B (closer to display) everything disconnected.
              PP20V_USBC_XB_VBUS 20.7v
              PP3V3_UPC_XB_LDO 3.25v
              PP1V8_UPC_XB_LDOA 1.81V
              PP1V8_UPC_XB_LDOD 1.80V...
              02-26-2024, 05:04 AM
            • TimScrawn
              MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
              by TimScrawn
              Hi there,
              This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
              I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
              06-23-2024, 09:41 AM
            • nikolayu
              MacBook Air A1932 internet recovery loop
              by nikolayu
              I have A1932 that is going to internet recovery every time.
              i tried nvram and smc reset but it looks that MacBook is not reacting to that.
              i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
              keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
              also won’t open option to boot from usb device.
              and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
              07-22-2025, 02:55 AM
