Strange Power Problem LA-D703P
  • ProSis
    • Jun 2017
    • 86
    • Turkey
    My motherboard model is LA-D703P Rev 3.0
    Motherboard problem no 3VALW & 5VALW when adapter is installed.
    But when I press the power button 3ALW & 5ALW comes up. but the device is not triggering.
    Has anyone come across a strange situation and solved it?
    Tried;
    Replaced RT8243A. Bios has been written.
  • mon2
    • 14012
    Re: Strange Power Problem LA-D703P
    What were the SMD markings on the original RT8243A ?
    What are the SMD markings of the replacement part for RT8243A ?
    • ProSis
      • Jun 2017
      • 86
      • Turkey
      Originally posted by mon2
      what were the smd markings on the original rt8243a ?
      What are the smd markings of the replacement part for rt8243a ?
      8a-
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        There is suspend logic involved here-so you wont get +3VALW/5VALW before turning on. They will appear only after turning on. Nothing wrong here. Check SIO basic requirements to begin with.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Duranitron
          Asus x512dk rev 2.1 power on problem
          by Duranitron
          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
          11-26-2024, 10:22 PM
        • EazyBone
          LG OLED55C9PUA power problem
          by EazyBone
          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
          The power supply to t con is different story.
          This...
          06-23-2023, 07:43 AM
        • Dr.d
          Help please..Lenovo ideapad 5 14itl05 power and charging problem
          by Dr.d
          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
          04-05-2024, 11:48 AM
          03-31-2024, 02:12 PM
