Samsung NP300E5E BIOS looping / power cycling
  • ACS-Repair
    • Feb 2021
    • 204
    Hello All,
    I have a customer's Samsung NP300E5E S01CA notebook that is BIOS boot looping / power cycling after they attempted a BIOS update. I got this third hand but I believe this is how the problem occurred.
    The splash screen comes up for about 1-2 seconds then power cycles this way continuously. I believe I'm going to need to reflash the BIOS to correct the problem. Would anyone have experienced this problem before?
    Board: BA41-02209A PIOTEK
    BIOS: P02RBD (original?)
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Samsung NP300E5E BIOS looping / power cycling
    If it doesnt detect a hdd, it will keep rebooting. So check whether its detecting HDD.
      • 21869
      Originally posted by ACS-Repair
      Hello All,
      flash the bios
      https://www.badcaps.net/forum/showthread.php?t=70092
      https://www.badcaps.net/forum/showpo...78&postcount=9
      • ACS-Repair
        • Feb 2021
        • 204
        Thank you mcplslg, I reconnected the hard disk, and while the screen did stay up longer, it didn't solve the problem. Good to know though.
        Thank you SMDFlea, The files on those links pointed to a different model and I had read about issues coming up in those cases. I was able to find a BIOS file, I believe on this board, that showed the correct model. I flashed it and it seems to be working OK now.
        Thank you both for your help. I'll include the file I used in case it can help someone else. https://www.badcaps.net/forum/showthread.php?t=105240
        • Kjell
          Samsung Series 9 - BIOS issue
          by Kjell
          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
          08-01-2025, 09:15 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • pirati
          by pirati
          Yesterday, 04:20 PM
