lenovo g50 power
  • mo000
    • Nov 2017
    • 285
    • algeria
    lenovo g50 power
    lenovo g50-70
    no power if lvds cable is attached
    i try other screen but same problem
    i try the lvds cable alone without screen the laptop has no power unless i disconnect the lvds cable .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenovo g50 power
    Do we still need to confirm that LVDS cable is short??
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • olliec420
      Nvidia Tesla P40 (Q0V80A) Enterprise GPU, I put the power cable on backwards.
      by olliec420
      Ok I screwed up big time and hoping I can fix. I will break down what happened and the images.
      • Have Dell PowerEdge R730
      • Bought Tesla P40
      • Researched power cables and order correct one, pic had two black connectors in photos
      • Power cable arrived, same connectors (EPS-12v) on both ends
        Both sides are the same plug but different colors. The listing stated that colors would be random. OK I plug it in, red side to riser board, black side to GPU.
      • Power on.
      • System immediately turns off.
      • I only had 1 PSU plugged in and it was blinking orange, I thought I drew too much so I plugged in
      02-11-2025, 07:29 PM
    • Mita99
      Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
      by Mita99
      Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
      Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
      Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
      04-27-2025, 07:20 PM
    • Dr.d
      Help please..Lenovo ideapad 5 14itl05 power and charging problem
      by Dr.d
      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
      04-05-2024, 11:48 AM
