Da0lx8mb6d1 REV.D LX89 CAPS BLINK
  • Umadbro
    • Jul 2018
    • 65
    • Portugal
    Hi. I have the following machine:
    HP Pavilion dv6-3156sg
    DA0LX8MB6D1 REV: D
    AMD CPU
    Turns on, black screen, CAPS flashing white every 4 seconds, wifi is solid amber.
    There was a little corrosion between two pads on the keyboard FPC, which I cleaned. No short. Tested bios flash but no luck. Tried slight reflow to GPU as reported to be a common issue on this model, no luck either.
    I am unsure if the dumps I used are propper for this mb, as there are many different versions I can find on the internet, and the recommended on this forum didn't work.
    Once again I tested all major coils/caps and no apparent shorts, the liquid damage between the kb points doesn't seem to have damaged adjacent capacitors. I will try to find the right schematic for this board. Could it be CPU? The hottest component in the motherboard once it's on for over a minute is the SOUTH BRIDGE ic (SB820), but not hot enough to point for short. Still, it burns while cpu/gpu haven't yet gotten ant heat on.
    will appreciate any help
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Da0lx8mb6d1 REV.D LX89 CAPS BLINK
    Usually dead RS880M northbridge. Should get hot pretty quickly without heatsink at least (don't leave it running like that for more than a few seconds).
    CPU must be S1g4.
    https://www.badcaps.net/forum/showpo...02&postcount=2
    Originally posted by piernov
    2.1. Never reflow large BGA
    It won't fix the problem since 99% of the time it's not an contact issue between the BGA and the logic board. There's a high risk of damaging the board even further.
    If you want to confirm if an AMD/NVidia chip is bad, you can heat it up to 200°C max for a minute and a half, no flux. It'll come back to life for a short while and then die again, because it's bad. In this case it has to be replaced.
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      CPU must be S1g4.
      Thank you for your help. I did use low temp, and only as a diagnostic test. The Northbridge didn't get hot, only South, I read later that NB is the usual culprit in this motherboard, on a rus forum. Unfortunately, I am unable to proceed with this repair as the customer preferred to invest in a more recent machine.
      I very much appreciate your concern and will I look out for this fault next time I get a similar machine.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • AdrenalinTL
        Caps and num lock blink 4 times
        by AdrenalinTL
        I am sitting with a very similar issue.
        Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
        Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
        Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
        Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
        04-09-2024, 10:34 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
