Macbook Pro A1989 820-00850-a not powering on
  • Simplebeans
    • Sep 2021
    • 135
    Hey guys i just got myself a Macbook Pro A1989 820-00850-a 2018, the seller said they had spilt liquid over it and since then it has never turned on.
    I am using a Apple 61W USB-C Power Adapter and USB-C Charge Cable and on my USB tester i can see when i plug into the power i get around 5.21V and stays at 0.24amps. I am currently testing disconnected from the battery and only plugged into the USB-C Charge Cable.
    When opening the machine I was greeted with corrosion on, in and around, in particular the U3100 (USB-C PORT CONTROLLER XA) and U3200 (USB-C PORT CONTROLLER XB) and some of the surrounding chips in the closer vicinity to these ACE controllers.
    The good news is the corrosion/signs of liquid ingress seem to be situated on this side of the board only. I have cleaned up the area using cotton buds & ISOPROPYL ALCOHOL 99.9%.
    I started to measure around the two CD3215's (U3100 & U3200) voltages for the following signals, (multimeter in voltage mode 20V) black probe to ground point and red probe at PIN #1:
    U3100:
    PP20V_USBC_XA_VBUS - 0V (measured at C3101 at PIN #1)
    PP3V3_UPC_XA_LDO - 3.34V (measured at C3108 at PIN #1)
    PP1V8_UPC_XA_LDOA - 1.80V (measured at C3106 at PIN #1)
    PP1V8_UPC_XA_LDOD - 1.80V (measured at C3105 at PIN #1)
    PP1V1_UPC_XA_LDO_BMC - 0V (measured at C3104 at PIN #1)
    U3200:
    PP20V_USBC_XB_VBUS - 1.40V - 0.31V fluctuating (measured at C3201 at PIN #1)
    PP3V3_UPC_XB_LDO - 3.34V (measured at C3208 at PIN #1)
    PP1V8_UPC_XB_LDOA - 1.80V (measured at C3206 at PIN #1)
    PP1V8_UPC_XB_LDOD - 1.79V (measured at C3205 at PIN #1)
    PP1V1_UPC_XB_LDO_BMC - 0V (measured at C3204 at PIN #1)
    PP20V_USBC_XB_VBUS (checking upstream) - 1.47 - 0.36V fluctuating (measured at F3001 at PIN #1 and #2)
    The PP20V_USBC_XB_VBUS signals seem to me, unstable. So I decided to check some more chips in the circuit. When checking Diode D3370, meter in diode mode and red probe to PIN #1 and black probe to PIN #2.
    The voltage drop is again fluctuating from 1.082V - .735V, when measuring reversed-biased i get the same voltage readings -fluctuating. I measured the capacitors C3360, C3366, C3361, C3363, C3364 and C3365 (meter in diode mode) red probe to ground point and black probe to each PIN #1 #2, at PIN #2 i am getting beeps for all the capacitors and at PIN #1 it is showing a good voltage drop for all capacitors. So no shorts, to me it seems.
    My thinking on this is Diode D3370 is bad because it is allowing the current to flow in both directions?
    What are your thoughts on this? I can continue to measure more signals for the boot sequence but wanted to gather some thoughts first.
  • mon2
    • Dec 2019
    • 14679
    Re: Macbook Pro A1989 820-00850-a not powering on
    Remove all power.
    Meter in lowest resistance mode (2k is ok).
    Measure the resistance to ground of:
    PP20V_USBC_XA_VBUS (Pin #1 of F3000)
    PP20V_USBC_XB_VBUS (Pin # 1 of F3001)
    Post the readings.
    Diode D3370 - can remove it and test the part out of circuit to be sure of the condition of this component. Use Diode mode of your meter to test.
    Without Diode D3370 - do you have the 5v on Vbus rails ?
    PP1V1_UPC_XA_LDO_BMC - are not working on either ACE controller and this rail is required for the BMC power delivery communication with the Type C adapter. Just a FYI but for now, need the 5 volts (default output of the power adapter) to be stable on each ACE controller.
    • Simplebeans
      • Sep 2021
      • 135
      Originally posted by mon2
      Remove all power.
      Post the readings.
      Hey mon2 i tried to measure at 2K resistance mode but that was producing a 0L reading for F3000 so tested it at by placing meter in resistance mode (200K) black probe to ground point and red probe to PIN #1:
      PP20V_USBC_XA_VBUS measured 58.6KΩ (Pin #1 of F3000)
      I then attempted to test at 200K but that was producing a 0L reading for F3001 so i tested that one by placing the meter in resistance mode (2M)
      PP20V_USBC_XB_VBUS measured 0.191MΩ (Pin #1 of F3001)
      I will go ahead and remove the Diode D3370 but there is one more issue i am have, the board is still stitting in the chassis and the reason for this is i stripped the screw heads for the two very small T3 Torx Screws that hold the aluminum cover over the display board flex cable.
      Any tips or tricks/information on how it would be possible to get these screws out at all?
      • mon2
        • Dec 2019
        • 14679
        Yes, invest in the proper tools. They are commonly available on Aliexpress.
        You should be able to remove the stripped screws with the proper flat head screwdriver or perhaps a robertson head tip. You will have to experiment.
        Worst case - use needle nose pliers but be prepared to damage surrounding parts that may be nearby.
        Best to have the proper tools before starting.
        • Simplebeans
          • Sep 2021
          • 135
          And thats the thing mon2, I have got the iFix Mako Precision Bit Set with the correct T3 Torx screw driver, which is exactly what i used for this.
          The other T3 screws i managed to get them out just fine i.e the four T3 Torx screws securing the plastic covers on top of the display hinges.
          These did not want to come out.
          • Simplebeans
            • Sep 2021
            • 135
            Hey mon2 i got the logic board out of the chassis, for anyone wondering what I did, I used a Torx T5 screwdriver (bigger size) so it filled out the stripped head and pressed down firmly to get a better grip and voilà! Both screws came out.
            I desoldered the Diode D3370 off and plugged in my USB tester and now it will remain on 5V for a few seconds and then go to 20V and show amps being drawn.
            I decided to put it all back together and connect everythng up by putting the logic board back into the chassis, just to make sure, and apple logo on screen! I am getting full fan spin so I will need to look into that but the machine is powering on now.
            Does anyone have a spare D3370 diode or point me in the right direction as to where i am able to purchase this one?
            Another thing which was strange was with the diode off the logic board i tried again to measure U3200 for signal PP20V_USBC_XB_VBUS at capacitor C3201 (PIN #1) but this time i was getting no voltage reading on the meter, i found that a bit of a odd one.
            • mon2
              • Dec 2019
              • 14679
              NSR20F40NXT5G
              https://www.aliexpress.com/wholesale...psort=1&page=1
              https://www.mouser.com/ProductDetail...=NSR20F40NXT5G
              https://lcsc.com/product-detail/Scho..._medium=buyNow
              • Simplebeans
                • Sep 2021
                • 135
                Cheers mon2, I appreciate that.
                • Simplebeans
                  • Sep 2021
                  • 135
                  Hey mon2, the saga continues...
                  I replaced Diode D3370 today onto the logic board and now I’m observing some different behaviors. CD3215 - U3200 is not taking any power at all, so, when i plug in the USB-C Charge Cable into the USB port associated with U3200 the USB tester shows me no voltage (so the USB tester will not turn on). I tested the signal at PP20V_USBC_XB_VBUS to clarify this by placing black probe to ground point and red probe at PIN #1 on C3201 (multi meter in voltage mode 200V) and i get 0V.
                  Now the other three CD3215's -U3100, UB300 & UB400 my USB tester is displaying fine and shows 5.21V - 0.25amps. I also measured the associated signals @ PP20V_USBC_XA_VBUS, PP20V_USBC_TA_VBUS, PP20V_USBC_TB_VBUS and all of them are measuring 5.1V so those ACE controllers are getting power.
                  To make sure the USB port was not bad i connected the USB-C Board over onto the other side of the logic board JB500 (FPC connector) and now when plugging in the USB-C Charge cable both ports are showing on the USB tester 5.21V - 0.25amps. So the ports on the USB-C Board are ok.
                  I am now thinking then this, might be on, now the U3200 actually being bad. What are your thoughts?
                  Is there anything else i should be checking for?
                  Oh gosh, i love under fill.
                  • mon2
                    • Dec 2019
                    • 14679
                    Remove this diode and test again (without the diode).
                    Respectively, this diode has a polarity. Please be sure it is being soldered in properly onto the board.
                    • Simplebeans
                      • Sep 2021
                      • 135
                      I checked the diode polarity and also followed the position of the solder pads, one pad being larger than the other. So thats the orientation i'd used. Also to confirm when I had put the Diode onto the board, the Anode was attached to ground pad, (bigger pad) and the Cathode, attached to the PP20V_USBC_XB_VBUS side pad (smaller pad). Although do correct me if i am wrong on this?
                      I have removed the D3370 Diode as suggested and now the USB port connected to U3200 is working again, when plugging in the USB-C Charge cable the USB tester is turning on and showing 5.21V - 0.25amps., even better still i tested again PP20V_USBC_XB_VBUS at PIN #1 on C3201 and it is showing now 5.1V! However it does fail to negotiate 20V, stranger even more still was the first 2-3 times i plugged in the USB-C Charge cable after removing the Diode it did get to 20V but did take a while time wise to negotiate to this from 5V.
                      And after checking now again for PP1V1_UPC_XB_LDO_BMC that has also come alive, so measuring it getting now 1.1V at Capacitor C3204 at PIN #1.
                      • mon2
                        • Dec 2019
                        • 14679
                        Remove all power.
                        Meter in diode mode.
                        Red meter lead (yes Red), to ground.
                        Black meter lead to each ldo on the ACE controller. Post the diode readings for each rail of the cd3215 device.
                        Do this for each ACE controller.
                        • Simplebeans
                          • Sep 2021
                          • 135
                          Remove all power.
                          Hey mon2
                          CD3215's (ACE controller) diode measurements:
                          U3100
                          PP3V3_UPC_XA_LDO measured at C3108 PIN #1 - .521
                          PP1V8_UPC_XA_LDOA measured at C3106 PIN #1 - .539
                          PP1V8_UPC_XA_LDOD measured at C3105 PIN #1 - .501
                          PP1V1_UPC_XA_LDO_BMC measured at C3104 PIN #1 - .532
                          U3200
                          PP3V3_UPC_XB_LDO measured at C3208 PIN #1 - .521
                          PP1V8_UPC_XB_LDOA measured at C3206 PIN #1 - .538
                          PP1V8_UPC_XB_LDOD measured at C3205 PIN #1 - .499
                          PP1V1_UPC_XB_LDO_BMC measured at C3204 PIN #1 - .533
                          UB300
                          PP3V3_UPC_TA_LDO measured at C3208 PIN #1 - .522
                          PP1V8_UPC_TA_LDOA measured at CB306 PIN #1 - .539
                          PP1V8_UPC_TA_LDOD measured at CB305 PIN #1 - .500
                          PP1V1_UPC_TA_LDO_BMC measured at CB304 PIN #1 - .532
                          UB400
                          PP3V3_UPC_TB_LDO measured at CB408 PIN #1 - .521
                          PP1V8_UPC_TB_LDOA measured at CB406 PIN #1 - .537
                          PP1V8_UPC_TB_LDOD measured at CB405 PIN #1 - 499
                          PP1V1_UPC_TB_LDO_BMC measured at CB404 PIN #1 - .531
                          • mon2
                            • Dec 2019
                            • 14679
                            Diode values look ok.
                            Meter in voltage mode.
                            Check the voltage of each ldo rail for the cd3215 that is being used to power the board.
                            Post the voltage readings.
                            Do any of the ports, even with if flipped around, allow for 20v ?
                            Suggest to only move the ports and cable when adapter is OFF (unplugged).
                            • Simplebeans
                              • Sep 2021
                              • 135
                              CD3215's voltage measurements:
                              U3100
                              PP3V3_UPC_XA_LDO measured at C3108 PIN #1 - .3.3V
                              PP1V8_UPC_XA_LDOA measured at C3106 PIN #1 - 1.7V
                              PP1V8_UPC_XA_LDOD measured at C3105 PIN #1 - 1.7V
                              PP1V1_UPC_XA_LDO_BMC measured at C3104 PIN #1 - 1.1V
                              U3200
                              PP3V3_UPC_XB_LDO measured at C3208 PIN #1 - 3.3V
                              PP1V8_UPC_XB_LDOA measured at C3206 PIN #1 - 1.7V
                              PP1V8_UPC_XB_LDOD measured at C3205 PIN #1 - 1.7V
                              PP1V1_UPC_XB_LDO_BMC measured at C3204 PIN #1 - 1.1V
                              UB300
                              PP3V3_UPC_TA_LDO measured at CB308 PIN #1 - 3.3V
                              PP1V8_UPC_TA_LDOA measured at CB306 PIN #1 - 1.7V
                              PP1V8_UPC_TA_LDOD measured at CB305 PIN #1 - 1.7V
                              PP1V1_UPC_TA_LDO_BMC measured at CB304 PIN #1 - 1.1V
                              UB400
                              PP3V3_UPC_TB_LDO measured at CB408 PIN #1 - 3.3V
                              PP1V8_UPC_TB_LDOA measured at CB406 PIN #1 - 1.7V
                              PP1V8_UPC_TB_LDOD measured at CB405 PIN #1 - 1.8V
                              PP1V1_UPC_TB_LDO_BMC measured at CB404 PIN #1 - 1.1V
                              And was not sure what you meant here about flipping them around? If you did mean taking the USB-C Board and connecting to both sides of the logic board at J3300 & JB500 (FPC connectors) i had to do this to perform the voltage tests above and none of the CD3215's were negotiating 20V.
                              • mon2
                                • Dec 2019
                                • 14679
                                LDO rails look fine.
                                Do any of the ports enable the 20v selection ?
                                Try flipping the Type C power cable upside down for testing.
                                Suggest to ONLY move the ports and cable when adapter is OFF (unplugged).
                                There is too much risk in cross-shorting the CCx lines against the Vbus. These ACE controllers are dying out in the field for a reason...
                                Update - just saw your update. Thanks.
                                What I meant was the the Type C connector on the power supply is flippable. There is the TOP SIDE of the blade connector and theire is a BOTTOM SIDE of the blade connector.
                                The power delivery interface makes use of the CC1 pin on one side and CC2 pin on the other side. So if you have attempted the power connection one way, remove it and flip it upside down and mate again. We only want to confirm if the results are the same, using BOTH sides of the blade.
                                Suggestion again to remove the power adapter -> mate the connector to the logic board -> power up again.
                                • Simplebeans
                                  • Sep 2021
                                  • 135
                                  I see what you mean now, the USB-C Charge cable from the 61W USB-C Power Adapter, so i plugged that in one way inot the USB port, and then turned it 180° and plugged in the other way and the USB meter shows me 5.21V both ways. That is tested on all 4 USB ports.
                                  • mon2
                                    • Dec 2019
                                    • 14679
                                    Ok. What is the voltage of PPBUS_G3H with the power adapter connected ?
                                    You can measure @ F7000, pin # 2. When the external power adapter is @ 5V (starting voltage by default), U7000 will become a BOOST regulator and boost the voltage to a higher value than the input (5 volts for your case).
                                    Once the 20V power delivery contract is negotiated and selected, U7000 will then become a BUCK regulator (will lower the 20V to the proper PPBUS_G3H voltage).
                                    • Simplebeans
                                      • Sep 2021
                                      • 135
                                      I measured PPBUS_G3H @ F7000 PIN #2 (meter in voltage mode 20V) black probe to ground point and red probe to Fuse F7000 PIN #2 and i am getting a reading of 12.29V, however when holding the probes at the position i do see the voltage fluctuating between 11.60V then back to 12.29V, this is not happening all the time and not in any regular timing just randomly.
                                      Oooo it fancy how this one Boosts and Bucks!
                                      • mon2
                                        • Dec 2019
                                        • 14679
                                        The voltage of PPBUS_G3H should not be fluctuating.
                                        Power down and desolder F7000 fuse. Then power up again and confirm if PPBUS_G3H is stable by measuring @ F7000, pad # 1 (fuse will not be in the circuit so there is no load from the consumer side of the circuit).
                                        • gugutm
                                          a1989 820-00850 stuck at 5v 0.041a Help
                                          by gugutm
                                          I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                                          long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                                          of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                                          01-04-2025, 09:35 AM
                                        • lapfix
                                          HP OMEN NO power no light
                                          by lapfix
                                          HP OMEN : DAG35DMBAD0
                                          NO power ,no short ,no corrusion
                                          Consumption : when charger plg in = 0.004 amp
                                          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                          No light at power button led
                                          All coils resistances :
                                          Pl 2001 =3v measured with kohm.
                                          pl 2004 = 5v measured with kohm
                                          pl 6001 = 49.7ohm
                                          pl 4012 = vccsa = 24.4 ohm
                                          pl 3001 =...
                                          11-03-2025, 07:48 AM
                                        • JimBanville
                                          MOSFET mystery
                                          by JimBanville
                                          N channel mosfets testing as P type?
                                          Working on a smps.
                                          Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                                          Removed a pair of mosfets marked 1L02AB FDP
                                          26N40 from the circuit.
                                          The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                                          I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                                          09-14-2023, 04:22 PM
                                        • tommy97
                                          MacBook A1989 No power
                                          by tommy97
                                          I’m having an issue with an A1989 board after water damage, it’s stuck at 5V 0.20A. I’ve checked the measurements, and all readings are the same across all four CD3215 chips. I replaced them one by one (using chips from a donor board), but nothing has changed.
                                          I don’t need a fully functional board, as the repair is only for data recovery purposes.
                                          • PP3V3_G3H: 3.3V
                                          • PPBUS_G3H: 12.26V
                                          • PP20V_USBC_XB_VBUS 5V
                                          • PP3V3_UPC_XB_LDO 3.3v
                                          • PP1V8_UPC_XB_LDOA 1.8V
                                          • PP1V8_UPC_XB_LDOD 1.8V
                                          • PP1V1_UPC_XB_LDO_BMC 1.1V
                                          Can the A1989 work with just one master CD3215? What would...
                                          10-16-2025, 01:57 PM
                                        • howardc64
                                          Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                                          by howardc64
                                          Samsung have been using this style LED connector for few years now
                                          Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                                          The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                                          10-12-2025, 08:13 PM
