asus k756u
  • nabilgo
    • May 2016
    • 303
    • L.A
    asus k756u
    asus k756u NO POST POWER UP BUT NO DATA ON THE SCREEN BUT I CAN SEE THE SCREEN BLACK WHEN POWER IT ON
    • 21973
    Re: asus k756u
    Anything on HDMI
    • nabilgo
      • May 2016
      • 303
      • L.A
      Re: asus k756u
      nothing
      • twonk9098
        • Aug 2018
        • 75
        Re: asus k756u
        Have you tried disconnecting the LCD whilst plugging a monitor into the HDMI port?
          • 21973
          Re: asus k756u
          When its unpowered .
          • nabilgo
            • May 2016
            • 303
            • L.A
            Re: asus k756u
            same probleme even i did disconected all the motherborad and i did plug external keyborad but still the same but when i did take off the ram and power the laptop on stll can see the screeeeen color becoming black
            • grimacelord
              HP 15-EH1070wm - Black Screen With Power LED.
              by grimacelord
              I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
              First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
              01-28-2023, 10:50 AM
            • Themonster
              Laptop Asus Strix G15 power up, but always black screen
              by Themonster
              Hi im Monster ("nickname"), i will explain what happens with this laptop pc:
              Asus Rog Strix G15 : model = G512LW
              The screen is not broken, almost not physically.
              When i power up the computer this run perfect but nothing show in screen, also in HDMI port.
              More or less 10 sec later, when win 11 is loaded , HDMI show things i mean user login in win 11.
              Original or main screen doesn't works, anytime, but HDMI works fine when win11 load nicely.
              When win11 is loaded , i check device administrator, and i found a system firmware error, so what...
              01-19-2024, 04:00 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • samolo75
              Asus Laptop GL702VS black screen power LED on
              by samolo75
              I am fighting with this laptop and I am suspecting of the GPU, but it would be great to know your opinion.
              The laptop originally does show black screen (no back light) but the power button LED turn on and off when pressing it.
              I did the next trouble shooting with no changes
              - Disconnected the battery and try just with the power supply
              - Disconnected all power sources, even the CMOS battery and held the power button for 40sec.
              - Disconnected hardrives
              - Deplaced the RAM
              - Disconnected the Wifi module
              - I connected a external monitor to the...
              03-31-2021, 03:16 PM
            • LazNo01
              Need help Asus x512d power on black screen
              by LazNo01
              asus x512d with ryzen 5 cpu, does power on but not image .
              when the battery is unplugged and only dc is conected the CPU gets hot and the fan start spinning at max speed ( it's like the laptop turn on automaticly after the dc in pluged )
              i did try with a new ddr4 ram but did help ( also the laptop has intgrated rams ) .
              i need help where to start the diagnonsis what can cause such issue !
              thank you.
              11-26-2024, 04:37 PM
