Need help Asus x512d power on black screen
  • LazNo01
    • Sep 2023
    • 21
    • Algeria
    asus x512d with ryzen 5 cpu, does power on but not image .
    when the battery is unplugged and only dc is conected the CPU gets hot and the fan start spinning at max speed ( it's like the laptop turn on automaticly after the dc in pluged )
    i did try with a new ddr4 ram but did help ( also the laptop has intgrated rams ) .
    i need help where to start the diagnonsis what can cause such issue !
    thank you.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Bein with measuring voltage on all coils. Link boardview,if available.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Start a new tread in Schematic only request to request for an schematic or board view of Asus x512dK
      and I will give you the board view of X512DK 60NB0LZ0-MB1610 Rev 2.1. if this is your model.
      Board view is much better than Schematics
      • LazNo01
        • Sep 2023
        • 21
        • Algeria
        here are two images inculding all the voltages i have , with power on and off .. i think everything looks normal on the power side ..
        • LazNo01
          • Sep 2023
          • 21
          • Algeria
          i do have the boardview but i don't know the exact steps to follow for diagnosis :p
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            here is the board view just download it. I also include boardview viewer for it.. happy hunting!!
            https://www.badcaps.net/filedata/fetch?id=3516744
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              measure all the coils in reference to ground. 1 prod connected to ground and 1 prod connected to measure coil. all coils must be have a resistance not less than 1ohm. coil connected to processor is low 1ohm but not shorted.
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                if the problem is no display try to measure the 19volts that is connected to the LVDS
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Connect a usb keyboard and check whether numlock key glows on toggle? We want to be sure whether mb is posting or not.
                  All the voltage rails seems present. Have you tried flashing bios?
                  Else,start measuring all the powergood signals with the help of boardview.
                  Dramrst# is present or not on ram slot?
                  What is the consumption on dc supply
                  01.With ram stick
                  02Without ram stick?
                  • LazNo01
                    • Sep 2023
                    • 21
                    • Algeria
                    01.With ram stick
                    nothing happend when i plugged the usb Keyboard.
                    and for pwrgood signals they are all messured when the laptop is on , when i turn off the laptop all of them showed 0v except 5vsus_pwrgd was the same as turn on.
                    5VSUS_PWRGD = 3.2V
                    ALL_SYSTEM_PWRGD = 3v
                    APU_PWRGD = 1.8v
                    CORE_PWRGD = 3.1v
                    DDR_PWRGD = 3.34v
                    P_1.2V_PWRGD_10 = 3.34v
                    VS_PWRGD = 3.37v
                    VSUS_PWRGD = 3.3v
                    Dramrst# is 0V ( test it without the ram cause there is no room to test it while the ram is plugged )
                    i can't know to laptop consumption , i don't have a bench power supply.
                    [ edit : i did flash the bios with a donor one ]
                    • mon2
                      • 14657
                      Dramrst# is 0V
                      This means you are stuck in reset mode. This line should be a logic '1' if in normal boot. The # suffix = active_low signal. If this line is low (ie. 0v) then the signal is active, parked in RESET mode.
                      • LazNo01
                        • Sep 2023
                        • 21
                        • Algeria
                        and that is a new thing i learnd here , thank you .
                        and what can be the issue for laptop to be stuck at RESET mode ?
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          RAM reset signal is irrelevant if there is no RAM plugged in, or it needs to have enabled on-board RAM.
                          • LazNo01
                            • Sep 2023
                            • 21
                            • Algeria
                            The on board ram is by default enabled, unless the issue here comes from the onboard ram.. and that's what I'm suspecting..
                            The laptop behavior didn't change with or without the ram.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              DRAMRST# must be at 1.2V as onboard ram is present. Check communication on SDA/SCL pins if you have DSO.
                              • LazNo01
                                • Sep 2023
                                • 21
                                • Algeria
                                according to the boardview there is MB_DQS_P0 and MB_DQS_N0 on the ram slot.
                                when turned on , MB_DQS_P0 = 0.68v , MB_DQS_N0 = 0V .
                                • Duranitron
                                  • Jul 2014
                                  • 544
                                  • Philippines
                                  Have you saved the original bios of your unit? Supply the original bios of your model and post it here include the model # the serial number# or service tag serial number, many of the generous and kind hearted people here will to the rest... 😊😊😊 Try to flash the bios with clean ME
                                  • LazNo01
                                    • Sep 2023
                                    • 21
                                    • Algeria
                                    I did flash it with a fresh bios, I think it's either the CPU or On-board ram.
                                    I have to find a way to disable the On-board ram, do know how to for that model?
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      Many Moderators here can determine either your bios is at fault. Just post the bios here to make sure that the bios is not faulty. all your voltage rail is normal. They can clear the ME region of your bios. Try that first before you jump in to the advance stage
                                      • LazNo01
                                        • Sep 2023
                                        • 21
                                        • Algeria
                                        It's an AMD cpu , doesn't have ME firmware .
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • Technodoc
                                          ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                                          by Technodoc
                                          Asus laptop G614JZ-N3012W Rog Strix with i7
                                          Mainboard G634J-PMV-VGT
                                          6050A3441302-MB-A01
                                          2023-02-10
                                          Power button works okay....power light goes on
                                          Red "bottom" leds go on
                                          Charging led works
                                          Fans do not spin, capslock key does nothing, screen stays black
                                          I would like to program the bios again, to rule out a corrupted bios.
                                          However I run into a size error
                                          The bios chip is a Winbond 25R256JVEN
                                          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                                          02-24-2025, 04:46 AM
                                        • andrestecno
                                          ASUS X201e - The screen does not turn on and remains black
                                          by andrestecno
                                          I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
                                          If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
                                          Thanks in advance!
                                          07-18-2024, 07:14 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
