MacBook Air 2018, no power at all after backlight repair
  • Win Me
    • Jan 2021
    • 30
    • France
    Hi, so I get a board 820-01521-02 today and I am really annoyed because it cames for a no backlight and full fan speed issues. So I solved the full fan speed issue by replacing resistors around a sensor chip. But then I get to solve the backlight issue, I saw 2 resistors (R8452 and R8453), they were blown, I replaced them. I powered up the machine (in the Mac case, with the battery pluged in and the screen pluged in) the amp meter get to around 20V 0,250amp, like a normal boot, then stops, no fan no screen, no battery charging and get to 20V 0,000amp, during boot.
    And now after testing all the rails for the T2, I found that the machine doesn't have PP5v_G3S, no PP3v3_G3S and no PP1v8_G3S. Non of them are shorted, the machine was perfectly working without backlight, I don't understand the resistors I replaced are non related to a direct communication with the T2 or PMU. I also don't hane any enable signals for the previous rail.
    Note: In Apple configurator I have an error message when I try to revive the board: Gave up waiting for device to transition from DFU state to DFU stave
  • mon2
    • 14667
    Re: MacBook Air 2018, no power at all after backlight repair
    Try to restore with another, shorter USB cable.
    • Win Me
      • Jan 2021
      • 30
      • France
      But mine is already very short. And it takes like 10 minutes before getting to the error
      • Win Me
        • Jan 2021
        • 30
        • France
        Plus my cable works, I already restored some Mac with it
        • Win Me
          • Jan 2021
          • 30
          • France
          So, for anyone having the same issue, I fixed mine. My issue was weird because when I was reseting the SMC my G3S rails came back but not any S5 rails were working and tthe SMC reset worked ONLY with a battery pluged in, with no battery the reset didn't do anything! I replaced R5240, the resistor was bad and Q6950, TADA the Mac works again.
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • Constantinos
            Macbook Pro A2442 820-02098 No image but has backlight
            by Constantinos
            Hi all
            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
            Obviously, he decided against this and gave it to me so that I could have a crack at it.
            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
            08-24-2024, 09:48 AM
          • wkholi
            Macbook pro 15" 2018. keyboard backlight not working
            by wkholi
            Hi. all
            I had to detach my MacBook pro 15 " 2018 (A1990) screen because it was broken.
            The keyboard backlight dies not. work anymore.
            Did I mess something up or the backlight cable is connected. to the screen?
            Thanks in advance
            08-07-2022, 07:58 PM
          • unimatrix93
            Identifying backlight resistors, power supply is a BN44-00852
            by unimatrix93
            Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
            The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
            The TV is pretty much always on, used for CCTV cameras.
            I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
            04-29-2024, 04:49 AM
