Asus FX504 not charging battery
before replacing the ec chip make sure you have 19v on the current sense ... if you dont have ... try to measure current sense resistor .. make sure the board was removed from the case and every peripherals on it ..Comment
No, do not replace ec till we know more about this case. Need to first confirm the battery charge circuit is ok. So far dealing with dead and wounded mosfets with solder shorts on the charger ic.
post pics of the dcin mosfets and this charger ic.Comment
However I want to know if I can check that PCH and EC are not damaged.Comment
In general - check if there are visual damages to the EC or PCH. If either have very low resistance to ground measurements for their power rails, then yes, it is possible that target or load is shorted.
If you are able to observe some power on led blink pattern, then the EC is probably OK since there is an internal micro running a local firmware that is performing this task. For now, leave these parts alone till we conquer the battery charger circuit to satisfaction.Comment
pch is not damage for me .. there is a chance in ec damages .. there is a communication between battery and ec and ec between charging ic so better to replace the this ec chip.. i solve a problem of asus x451ma that the battery icon is not detected ( battery pluggedin) but not charging when adapter is removed laptop is not powering off , i change the ec and the laptop works perfectly.. i found out that the sda / scl lines reading was 400ohm .. maybe you can get something on my case to your caseComment
To summarize the overall problem, there is not current in PQ21's gate.
Which is the purpose of PC180 and PC181?Comment
I have found this thead in a TI forum. They explain the purpose of both capacitors C_GS and C_GD.
C_GD is the capacitance between the gate and drain. This capacitance and the combined total gate capacitance (C_G) must be fully charged for the MOSFET to switch on.
The significance of this is that the charge pump on ACDRV has a limit of 60 uA. By keeping the gate capacitance or gate charge low, you can reduce your turn on time.
https://e2e.ti.com/support/power-man...cfet-and-rbfet
In this one it is say that they only control how fast FETs are turned on and the input current but it's omission (and I think malfuction) should not avoid that FETs turn on.
https://e2e.ti.com/support/power-man...tion-questionsComment
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by johnbetonHello,
I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
So far I measured all the pins on the bq24780s controller with the following result:
1. ACN = 0.0V
2. ACP = 19.02V
3. CMSRC = 18.5V
4. ACDRV = 23.9V
5. ACOK = 5.9V
6. ACDET = 2.57V
7. IADP = 0.17V
8. IDCHG = 0V
9. PMON = ?
10. PROCHOT = 5.05V
11. SDA = 3.3V
12. SCL = 3.3V
13. CMPIN = 0.47V
14. CMPOUT = 6.0V
15. BATPRES = 0.0V
16.... -
by dqtechearly problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile... -
by ShinjuHey All!
Long time forum member here with a problematic laptop issue!
I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
The laptop would not power on with the new battery installed without the power supply being plugged in.
When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows... -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... - Loading...
