Asus FX504 not charging battery
  • alfredposadas09
    • Aug 2020
    • 342
    • Philippines
    #61
    Originally posted by DavidRM
    Thanks it was a check to see it was worth to continue or not.
    The reason is that I have placed a MOSFET whose source and drain were shorted in PQ21. Since I was working fine before and I thought that there was no problem. But I have read that there is the risk of feeding the CPU with 19V, burning it.
    Apart of that, with that defective MOSFET in PQ21 and a good MOSFET in PQ22 my laptop was able to power on.
    However now it does not. Since the topic is related with a laptop that can work like a desktop but it does not charge the battery (or the case in which works as laptop but not recognized AC adapter).
    What can cause that the laptop doesn't power on?
    I have read that the main cause is a failure in power supply, but is there a were to check if more hardware involved in power on process has been damaged?
    have you try to replace the ec chip? try to replace ec chip
    • alfredposadas09
      • Aug 2020
      • 342
      • Philippines
      #62
      before replacing the ec chip make sure you have 19v on the current sense ... if you dont have ... try to measure current sense resistor .. make sure the board was removed from the case and every peripherals on it ..
      • DavidRM
        • Sep 2024
        • 13
        • Spain
        #63
        Is there a way to check if that ec chip (it is the ITE8987E) is damaged?
        How can I check if PCH has been damaged?
        • mon2
          • Dec 2019
          • 14672
          No, do not replace ec till we know more about this case. Need to first confirm the battery charge circuit is ok. So far dealing with dead and wounded mosfets with solder shorts on the charger ic.
          post pics of the dcin mosfets and this charger ic.
          • DavidRM
            • Sep 2024
            • 13
            • Spain
            #65
            Yes, I will recieve MOSFETs on Wednesday. I know that we have to solve charging issues first.
            However I want to know if I can check that PCH and EC are not damaged.
            • mon2
              • Dec 2019
              • 14672
              In general - check if there are visual damages to the EC or PCH. If either have very low resistance to ground measurements for their power rails, then yes, it is possible that target or load is shorted.
              If you are able to observe some power on led blink pattern, then the EC is probably OK since there is an internal micro running a local firmware that is performing this task. For now, leave these parts alone till we conquer the battery charger circuit to satisfaction.
              • linhgemn
                • Dec 2021
                • 5
                • Vietnam
                #67
                All you have to do is replace this aluminum capacitor. Why? Message me, I will explain.
                • alfredposadas09
                  • Aug 2020
                  • 342
                  • Philippines
                  #68
                  pch is not damage for me .. there is a chance in ec damages .. there is a communication between battery and ec and ec between charging ic so better to replace the this ec chip.. i solve a problem of asus x451ma that the battery icon is not detected ( battery pluggedin) but not charging when adapter is removed laptop is not powering off , i change the ec and the laptop works perfectly.. i found out that the sda / scl lines reading was 400ohm .. maybe you can get something on my case to your case
                  • DavidRM
                    • Sep 2024
                    • 13
                    • Spain
                    #69
                    MOSFETs have been replaced but ACDREV does not have proper voltage. VCC and ACDET are OK.
                    To summarize the overall problem, there is not current in PQ21's gate.
                    Which is the purpose of PC180 and PC181?
                    • DavidRM
                      • Sep 2024
                      • 13
                      • Spain
                      #70
                      I have found this thead in a TI forum. They explain the purpose of both capacitors C_GS and C_GD.
                      C_GD is the capacitance between the gate and drain. This capacitance and the combined total gate capacitance (C_G) must be fully charged for the MOSFET to switch on.
                      The significance of this is that the charge pump on ACDRV has a limit of 60 uA. By keeping the gate capacitance or gate charge low, you can reduce your turn on time.
                      https://e2e.ti.com/support/power-man...cfet-and-rbfet
                      In this one it is say that they only control how fast FETs are turned on and the input current but it's omission (and I think malfuction) should not avoid that FETs turn on.
                      https://e2e.ti.com/support/power-man...tion-questions
                      • johnbeton
                        Asus X415EA not charging battery
                        by johnbeton
                        I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                        So far I measured all the pins on the bq24780s controller with the following result:
                        1. ACN = 0.0V
                        2. ACP = 19.02V
                        3. CMSRC = 18.5V
                        4. ACDRV = 23.9V
                        5. ACOK = 5.9V
                        6. ACDET = 2.57V
                        7. IADP = 0.17V
                        8. IDCHG = 0V
                        9. PMON = ?
                        10. PROCHOT = 5.05V
                        11. SDA = 3.3V
                        12. SCL = 3.3V
                        13. CMPIN = 0.47V
                        14. CMPOUT = 6.0V
                        15. BATPRES = 0.0V
                        16....
                        05-19-2025, 04:05 AM
                      • dqtech
                        acer travelmate p214 status "charging" but battery percentage not increasing...0mW charge rate
                        by dqtech
                        early problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
                        i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
                        schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile...
                        05-04-2025, 04:42 AM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Shinju
                        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                        by Shinju
                        Hey All!
                        Long time forum member here with a problematic laptop issue!
                        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                        The laptop would not power on with the new battery installed without the power supply being plugged in.
                        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                        10-20-2021, 04:58 PM
                      • drlarsen
                        MacBook Air M1 A2337 battery/charging issue
                        by drlarsen
                        Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                        I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                        On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                        After some hours, the battery status did not improve. Restore via DFU did not help.
                        I connected the power adapter to a Kill-a-Watt...
                        07-17-2025, 02:35 PM
