Asus FX504 not charging battery
  • Roll
    • Mar 2022
    • 36
    • Czech Republic
    Re: Asus FX504 not charging battery
    Without anything connected it's about 35k ohms. With battery connected - 0 ohms
    • mon2
      • Dec 2019
      • 14669
      The battery is defective as this pin should not be 0 ohms when connected to the logic board.
      This P_CLK pin is a signal that is used for communication with the logic board to share the battery properties, charge level, etc. Without this signal, the communication cannot proceed.
      Suggest to source another battery and test again.
      Do update this thread.
      • Roll
        • Mar 2022
        • 36
        • Czech Republic
        Thanks for your help. I will order a new battery and will let you know
        • Roll
          • Mar 2022
          • 36
          • Czech Republic
          So I got a new original Asus battery and.... it's the same issue. Without battery laptop works on AC charger, but when I plug it in, it does not charge and works on the battery power.
          But when I use some random 19V power supply, it magically starts charging. But only after a reboot. When I unplug and plug it again, then it starts using battery again.
          With original PS it does not work even after a reboot
          • mon2
            • Dec 2019
            • 14669
            What is the voltage of P_CLK with the new battery ?
            • Roll
              • Mar 2022
              • 36
              • Czech Republic
              #26
              About 3,25 V on both clk and data
              • mon2
                • Dec 2019
                • 14669
                That is an improvement over the 0v for past P_CLK value.
                Remove PQ23 (battery mosfet) and test again.
                • Roll
                  • Mar 2022
                  • 36
                  • Czech Republic
                  #28
                  Now the laptop thinks it's charging all the time. When I unplug and replug the charger it does not drain the battery anymore. It does not charge.
                  • mon2
                    • Dec 2019
                    • 14669
                    If you leave this battery mosfet off the board and continue to leave in the 'charge mode' with the power adapter, does the battery pack actually charge ?
                    Allow it to remain in this state for 30mins - 1 hour and check the voltage again on the battery pack - without the adapter.
                    What is the voltage of MBATV ?
                    Check if the attached thermal sensing parts are stuffed on your logic board.
                    • Roll
                      • Mar 2022
                      • 36
                      • Czech Republic
                      #30
                      I don't think it is charging, voltage of battery is still the same - 11,52 V. With adapter or without.
                      MBATV is 2,15 V.
                      I will check the sensor tommorow.
                      • mon2
                        • Dec 2019
                        • 14669
                        Ok. When you are back at it...
                        1) check the voltages on ILIM (pin # 21) and ACDET (pin # 6) with the battery and charger attached. Still leave the battery mosfet (PQ23) off the logic board.
                        2) remove all power -> meter in resistance mode -> check the resistance values of the resistors @ ILIM (pin # 21). Do the resistor values match the schematic values ?
                        3) Does the BAT+ (battery connector voltage) increase when you apply the AC power adapter ? If not, the high side (PQ26) and low side (PQ27) mosfets need to be reviewed again.
                        With no power -> meter in resistance mode -> check the resistance across each mosfet pins:
                        source (1-2-3) & drain (5-6-7-8)
                        source (1-2-3) & gate(4)
                        gate (4) & drain (5-6-7-8)
                        Post the measurements and the scale used on your meter for these checks.
                        • Roll
                          • Mar 2022
                          • 36
                          • Czech Republic
                          #32
                          This board does not have PU38 and its components fitted.
                          ACDET is 2,66 V, ILIM = 0,71 V. without power it has resistance of 11,9k ohms.
                          PR225 should be 45k, measures 35k (on the board, so it looks fine), PR226 measures 12k.
                          Bat+ voltage does not increase.
                          PQ26:
                          S-D starts at 50k, goes up for 2M.
                          S-G 9,3k
                          G-D 3,75k
                          PQ27:
                          S-D starts at 15k, goes up for 150k
                          S-G 200k
                          G-D 200k
                          BTW thanks for your help. You're amazing!
                          • mon2
                            • Dec 2019
                            • 14669
                            PQ26 mosfet resistance looks low.
                            What is the voltage of BATPRES# pin 15 ?
                            • Roll
                              • Mar 2022
                              • 36
                              • Czech Republic
                              #34
                              BATPRES is 0V with or without the battery.
                              What is purpose of the PQ23 (removed) anyway?
                              I am not sure anymore, but I think I replaced the charging FETs from some other MB I had lying around. Now it has AON7410, it should have AON7506 according to schematic, but they looked simmilar enough for test. I can order new ones, but I doubt it will help
                              EDIT: yes I have replaced them, it's on first page, lol.
                              • mon2
                                • Dec 2019
                                • 14669
                                BATPRES# will be ok with 0v but see attached.
                                Locate the small mosfet on BAT_PRS# line.
                                Do you have this circuit stuffed on your logic board ?
                                WITHOUT the battery, the mosfet (PQ88) should be OPEN. If PQ88 is open, PR531 will pull-up this line to ~3v. Review if you have PR531 onboard and also measure the +3VPCU rail. It should be present.
                                1) Post the voltages on each pin of the HIGH and also the LOW side charging mosfets (PQ26 & PQ27).
                                Source (1-2-3)
                                Gate (4)
                                Drain (5-6-7-8)
                                Also measure the voltage @ pin # 4 (GATE) of the missing mosfet @ PQ23 (battery mosfet).
                                2) Also need the voltage readings of the pins # 19 & 20 on the charger IC.
                                Voltage on ACOK pin # 5 of the charger IC ?
                                Voltage on ACDET pin # 6 of the charger IC ?
                                Do connect the battery during the above testing.
                                3) We want to leave out the battery mosfet (PQ23) till we can confirm the charger is working properly.
                                • Roll
                                  • Mar 2022
                                  • 36
                                  • Czech Republic
                                  #36
                                  Mosfet and its components are not installed. +3VPCU - 3,3 V
                                  Battery installed, ASUS charger plugged in:
                                  PQ26:
                                  S - 11,44 V (same as battery voltage)
                                  D - 19,34 V
                                  G - 11,44V
                                  PQ27:
                                  S - GND
                                  D - 11,44 V
                                  G - 0 V
                                  PQ23:
                                  G - 11,44 V
                                  PU15:
                                  SRN - 11,44 V
                                  SRP - 11,44 V
                                  ACOK - 3,25 V
                                  ACDET - 2,67 V
                                  BTW where did you get the schematic? I only have boardview
                                  • mon2
                                    • Dec 2019
                                    • 14669
                                    Have you replaced mosfet PQ22 yet ? If not, do so.
                                    • Roll
                                      • Mar 2022
                                      • 36
                                      • Czech Republic
                                      #38
                                      I have not replace it since the laptop worked on adapter just fine. But I have ordered 3 pieces to replace PQ21-23 and also 2 new charging FETs for PQ26 and PQ27. It should arrive next week, I'll let you know about the result.
                                      EDIT: sorry about double post, internet issues...
                                      • Roll
                                        • Mar 2022
                                        • 36
                                        • Czech Republic
                                        #39
                                        I have replaced both main and both charging FETs and again, no charge.
                                        When I measure the PQ22 I only have 10,9V on VA line. That's too low, right?
                                        • Roll
                                          • Mar 2022
                                          • 36
                                          • Czech Republic
                                          #40
                                          I have no idea what happend, but after replacing the PQ21 and PQ22 the motherboard is dead again. I get 20V on VA+, but nothing on the VA. I put back original FETs, but nothing has changed.
                                          When I plug in the battery it powers on normally, but still doesn't charge and now it doesn't run on AC at all.
                                          I give up on battery charging, I just want the laptop to work on AC again as a desktop replacement. Is it bad idea to short VA and VA+ ?
                                          • johnbeton
                                            Asus X415EA not charging battery
                                            by johnbeton
                                            I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                                            So far I measured all the pins on the bq24780s controller with the following result:
                                            1. ACN = 0.0V
                                            2. ACP = 19.02V
                                            3. CMSRC = 18.5V
                                            4. ACDRV = 23.9V
                                            5. ACOK = 5.9V
                                            6. ACDET = 2.57V
                                            7. IADP = 0.17V
                                            8. IDCHG = 0V
                                            9. PMON = ?
                                            10. PROCHOT = 5.05V
                                            11. SDA = 3.3V
                                            12. SCL = 3.3V
                                            13. CMPIN = 0.47V
                                            14. CMPOUT = 6.0V
                                            15. BATPRES = 0.0V
                                            16....
                                            05-19-2025, 04:05 AM
                                          • dqtech
                                            acer travelmate p214 status "charging" but battery percentage not increasing...0mW charge rate
                                            by dqtech
                                            early problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
                                            i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
                                            schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile...
                                            05-04-2025, 04:42 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Shinju
                                            Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                            by Shinju
                                            Hey All!
                                            Long time forum member here with a problematic laptop issue!
                                            I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                            The laptop would not power on with the new battery installed without the power supply being plugged in.
                                            When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                            TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                            10-20-2021, 04:58 PM
                                          • drlarsen
                                            MacBook Air M1 A2337 battery/charging issue
                                            by drlarsen
                                            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                            After some hours, the battery status did not improve. Restore via DFU did not help.
                                            I connected the power adapter to a Kill-a-Watt...
                                            07-17-2025, 02:35 PM
