A1990 820-01326-05 stuck on 20v
  • sdogs
    • Feb 2016
    • 86
    • Italy
    thank you for allowing me to participate in this Forum, as a hobby I delight in the repair of macbooks, I am a beginner, I have this macbook that I bought to try to get it back in operation.
    At the first attempt it turned on it seemed to have a correct absorption of amps and seemed to charge the battery, from the beginning there seemed to be activity as the trackpad seemed to respond to impulses. Obviously it never turned on, no sound, the fans never turned. It does not heat in any point, observed with a thermal imager. A newbie question, does this type of macbook start up with no battery connected?
    I tried before and to perform other operations a DFU restore but it was not successful returning errors almost at the end of the process.
    The logic shows no signs of the presence of oxides or liquids.
    It has a strange behavior, without battery connected it remains stable at 20v but with variable absorption from 0.03A-0.07A if I connect the battery v from 20v to 5v, cyclically.
    Here are the measurements I made:
    PPBUS_G3H - 12,60v
    PPBUS_HS_CPU - 12,60v
    PPBUS_HS_OTH5V - 12,60
    PP5V_G3S - 5v
    PP3V3_G3H_T - 3,3
    PP2V5_NAND_SSD0 = 2,5v
    PP1V8_SSD0 = 1,8v
    0V9_SSD present and stable
    U7701
    Pin 12 5,1v
    Pin 6 2,8v to 3,1v oscillating and unstable
    Pin 16 0v
    Pin 17 0v
    L8102 0.06
    L7030 0.43
    L7701 0.08
    L8410 0.78
    LB700 0.26
    L7660 0.40
    Also it has a strange behavior, a continuous variation of the voltage on r3460 and r3450, from 0.5v to 1.8v with continuous oscillation, I replaced u3200 and it is now stable on 0.8v
    I repeat, I am a beginner, forgive me if I make any mistakes in the description :giggle:
  • mon2
    • Dec 2019
    • 14012
    Re: A1990 820-01326-05 stuck on 20v
    Can you post the schematic and boardview files for the 820-01326-05 ? Do not see these in my database.
    Remove all power -> meter in resistance mode.
    Check the resistance to ground of U7701, pin 6 that is oscillating.
    More after reviewing the schematics.
    • sdogs
      • Feb 2016
      • 86
      • Italy
      unfortunately I have not found that schematic anywhere and am trying to compare with 820-01041.
      As soon as I get home in the afternoon I will carry out the test you suggested on U7701 pin 6
      Tks ;-)
      • sdogs
        • Feb 2016
        • 86
        • Italy
        now the situation has changed, without changing other components:
        PPBUS_G3H - 12.60v
        PPBUS_HS_CPU - 12.60v
        PPBUS_HS_OTH5V - 12.60
        PP5V_G3S - 5v
        PP3V3_G3H_T - 3.3
        PP1V8_SSD0 = 1,8v
        U7701
        Pin 12 - 5,1v
        Pin 6 - 0V
        Pin 16 - 0v
        Pin 17 - 0,20v
        u7701
        resistance to mass
        PIN 6 - 50 kΩ
        pin 17 - 83 kΩ
        pin 16- slowly increases > 180Ω>>>>>>>
        • sdogs
          • Feb 2016
          • 86
          • Italy
          what will it be that triggers this instability? unfortunately my skills are not that advanced .... I'm stalled
          • mon2
            • Dec 2019
            • 14012
            For now, do not use the battery.
            Reaching 20v with adapter is a good sign to validate that each of the ACE controllers is working to allow for this power delivery contract.
            Meter in diode mode.
            Remove all power to the logic board.
            Red meter probe to ground (yes red probe).
            Black meter probe to point to test.
            Check diode mode to ground on all power rails of SSD.
            Post the values.
            • sdogs
              • Feb 2016
              • 86
              • Italy
              here are the measures, after, i also read the tensions, i hope it is right
              PP3V3_G3H_SSD0_SNS = 0,40
              PP3V3_G3H_SSD1_SNS = 0,40
              PPBUS_G3H_SSD0_SNS = 0,37
              PPBUS_G3H_SSD1_SNS = 0,37
              PP3V3_G3H_SSD0_SNS = 3,3v
              PP3V3_G3H_SSD1_SNS = 3,3v
              PPBUS_G3H_SSD0_SNS = 12,60v
              PPBUS_G3H_SSD1_SNS = 12,60v
              • sdogs
                • Feb 2016
                • 86
                • Italy
                I'm not very experienced but they would seem normal values, am I doing something wrong?
                • mon2
                  • Dec 2019
                  • 14012
                  Remove all power. Meter in diode mode.
                  Red meter probe (yes red probe) to ground.
                  Black meter probe to test point:
                  PP1V8_SLPS2R
                  What is the reading ?
                  • sdogs
                    • Feb 2016
                    • 86
                    • Italy
                    thank you very much for the help you are giving me ;-), you are very kind
                    here is the measurement:
                    PP1V8_SLPS2R 0,37
                    • sdogs
                      • Feb 2016
                      • 86
                      • Italy
                      can i do other tests? :testa di botto:
                      • sdogs
                        • Feb 2016
                        • 86
                        • Italy
                        PP1V8_SLPS2R 0,37
                        can i do other tests? :pensiero:
                        • ahoonid
                          A1990 820-01326 stuck at 5v and 0.19A
                          by ahoonid
                          Hi everyone.
                          I have a MacBook Pro 15" A1990 touchbar with (I believe) a dedicated Vaga GPU. The exact Boardview and schematics doesn't seem to exist but I've been using the one for 820-01814 so far.
                          The MacBook doesn't turn on, stuck at 5v and drawing only 0.19A.
                          All 4 USB Cs ports behave exactly the same.
                          There's no PPBUS G3H available.
                          The resistance to ground from PPBUS G3H is 0.4 ohm. I have found the same resistance to PPBUS G3H from two coils near cpu/gpu area.
                          Since the boardview I have is different exactly in this...
                          05-20-2025, 04:31 AM
                        • Fisher8865
                          MacBook Pro A1990 stuck at 5v .592 amps
                          by Fisher8865
                          Hi guys
                          I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                          05-30-2024, 07:36 PM
                        • DATATECH85
                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                          by DATATECH85
                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                          Here are the values...
                          07-24-2024, 06:34 AM
                        • mr.Data
                          Macbook A1990 stuck on logo
                          by mr.Data
                          This Macbook Pro 2018 boots up and then gets stuck on the logo.
                          All the normal methods of resetting this Macbook have been tried but do not work.
                          I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                          Any help would be greatly appriciated....
                          04-18-2024, 11:51 PM
                        • pcash0007
                          Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
                          by pcash0007
                          First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
                          I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
                          PPDCIN_G3H is 5.16V​
                          PPBUS_G3H is 0.045V
                          Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
                          F7000 and F7001 seems fine.
                          From what I learnt seems like there might be short on the down side on PPBUS_G3H.
                          Is injecting low voltage and see what...
                          03-07-2024, 06:19 PM
