Lenovo B51-80 / LA-D101P - No Battery Power
  • tolgaaydin
    • Jul 2020
    • 11
    • Bursa
    My Lenovo B51-80, which I forgot the battery on a long time ago, did not react at all when I tried to run it with the battery today. It works fine with the adapter. When I try a new battery it still doesn't respond.
    I made the measurements of the battery/charger integrated. I'm very new to repair and I'm waiting for your help.
    thank you all so much in advance.
    Note: Sorry if the translation is wrong.
    BQ24780
    ACN - 21.1v
    VCC - 20.7v
    REGN - 6.1v
    ACOK - 3v
    AVDRV - 26.4v
    ACDET - 2.6v
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Lenovo B51-80 / LA-D101P - No Battery Power
    You have to try with a new battery rest of the pin out supply ? Example pin 18 12 11
    • tolgaaydin
      • Jul 2020
      • 11
      • Bursa
      BATDRV - 00.2v
      SCL - 3.1v
      SDA - 3.1v
      (Measurements were made with the battery and adapter attached.)
      • tolgaaydin
        • Jul 2020
        • 11
        • Bursa
        LA-D101P schemactics, if anyone has, can they share?
        • mon2
          • Dec 2019
          • 14012
          With only a known good battery (no adapter), measure the voltage of each pin of the BQ24780.
          Post the measurements.
          Do this very carefully with patience and proceed only if you can take measurements without shorting to other pins.
          After this, remove all power. Meter in resistance mode (2k scale).
          Check the resistance of the battery mosfet:
          Source(1-2-3) and drain (5-6-7-8)
          Source (1-2-3) and gate (4)
          Gate (4) and drain (5-6-7-8)
          Post the readings. You can locate the battery mosfet by tracing the BATDRV pin on the charger IC.
          • ferah831208
            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
            by ferah831208
            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
            03-18-2025, 01:18 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • code share
            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
            by code share
            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
            Here's what I've tried so far:
            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
            • Booted successfully on AC power only with the battery disconnected
            • Visual inspection of the battery — no swelling, burn marks, or connector damage
            • Battery
            04-21-2025, 12:50 PM
          • mrkmpn
            Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
            by mrkmpn
            Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
            This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
            03-13-2024, 01:54 PM
          • pabloroggeri
            Lenovo V310-15ISK - It doesn't work after changing the battery
            by pabloroggeri
            Good guys. I changed the battery to a Lenovo V310-15ISK.
            The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
            When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
            08-23-2024, 12:01 PM
