Hi everybody, recently I bought for cheap an HP laptop (model HP G62-100SL) to make practice in repairing, just for hobby.
I want to stress, the fact that I'm a newbie to electronic repairing.
As I suspected the problem was simply a GPU that needed a reflow/reballing so nothing interesting. After the reflow the pc started to operate normally again.
There was just a problem, using a DELL 65w AC adapter, the battery charged but the AC adapter was not recognized by Windows and the laptop refused to start without the battery.
Now I guess that probably the reason was the fact that I was not using an original HP adapter, but at that time I was convinced that there was something wrong with the first MOSFETs of the power circuits.
Following a series of very bad actions guided by my ignorance:
- Firstly I confused the MOSFETs of the 5v step down as the power circuit MOSFETs just because they were the nearest to the 19v plug
- Then I obviously measure 6v instead of the 19v I was expecting, so I though that the problem was the second MOSFET not receiving the enable voltage on the gate.
- So I decide to remove the second MOSFET (low side), short the source and the drain and plug the charger. "Unexpectedly" the laptop stopped to work: no power led, nothing.
- Then I remove the short and plugged the AC adapter again.
"Probably" I should have read good guides like the ones that I later found in this forum and also "maybe" took a look at the schematics before doing this mess.
A brief recap of the current state and the tests I've made:
- The MOSFET I shorted is the low side of the 5v step down. 19v in input and nothing after the first or second MOSFET. No voltage on the gates.
- 19v after the current sensing resistor
- No shorts on the main power rail
- Charger IC seems to be powered. I attached few images with all the measures with AC adapter plugged in.
- 3.3v missing on power button
- No AC adapter led
- No shorts on the board and all the fuses seem ok
Board: DA0AX1MB6F0 REV:F
PC specs: Core I3 330M, Radeon 5430
I kindly ask for a hint of what I should check and thank you for anything that can improve my knowledge. I'm here to learn.
- No AC adapter led
