Apple A1989 no Sound
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    I have an A1989 and it had some liquid on it. Nothing is visible on the board. Everything works! But I only have one short sound on the left speaker. When I ask Siri about the weather, there is only one sound on the left, after that there is no more sound!
    Even if I restart once briefly sound then nothing more.
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Apple A1989 no Sound
    You need to check areas around U6300, U6400, U6450, U6500 and U6550, these are the audio and speaker controllers, check for liquid damage or bad traces.
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      I did it looks all ok!
      • mon2
        • Dec 2019
        • 14267
        Can you play music and/or Youtube videos with sound normally ?
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          Hi, I just played a youtube video and had sound on the left side! On the right I had no sound! But when I closed the page and opened it again I had no sound! The sound is always just left.
          • mon2
            • Dec 2019
            • 14267
            What is the 820-xxxx number markings on your logic board? This will help to locate the proper schematic for reference.
            • Strolch
              • Nov 2017
              • 237
              • Deutschland
              850
              • mon2
                • Dec 2019
                • 14267
                See attached.
                Measure the voltage on both sides of R5305 & R5306. These are the local pull-up resistors for the RIGHT side of the audio amp circuit for this open-drain circuit. These resistors are required to define the soft 'high' logic level.
                What are the readings for the respective,
                I2C_SPKRAMP_R_SCL
                I2C_SPKRAMP_R_SDA
                signal lines ?
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  Hi, i have on R5305 and R5306 both sides 1,7930 Volts
                  • mon2
                    • Dec 2019
                    • 14267
                    Voltage readings look fine and this implies the local pull-up resistors are pulling up the I2C lines to the 1v8 rail.
                    Confirm that the audio amp (U6550) is being powered - check for the 1v8 rail on the linked parts. See attached.
                    Any sign of liquid damage in this area ? The U6550 component is a WLCSP package (tiny BGA) which may need some TLC with flux and reflow -> tweezers to make it dance if you suspect corrosion which may be under the package.
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      Everything looks very good. And 1.79 volts are there
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        you think the U6550 is damage?
                        • mon2
                          • Dec 2019
                          • 14267
                          Perhaps but confirm the voltage as per attachment for the VBAT pins. You can check this on the caps.
                          Then confirm that L6550 & L6551 are present on the logic board. These are acting like filters but they must mate onto the woofer connector.
                          Remove all power, meter in resistance mode -> check the resistance between:
                          L6550, pin # 1 and # 2 - should be ~0 ohms
                          L6551, pin # 1 and # 2 - should be ~0 ohms
                          then check resistance between pin # 1 -> woofer connector as per attachment.
                          Need to be sure that both P (Positive) and N (Negative) leads of the speaker are reaching the pin # 1 of the respective ferrite beads.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            one question are the TAS5770LB2 and the TAS5770LB2YFR ,TAS5770LB. All the same? I want to order some
                            • Strolch
                              • Nov 2017
                              • 237
                              • Deutschland
                              i will check L6550, L6551...after a bike ride ;-)
