HP G6-1270EC black screen
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have here this laptop water damaged little bit. After cleaning laptop turn on fan is spinning, but only black screen. And caps lock blink continuously. Then I found bad resistor near PU11, PR207 -360K. I replace it with 330K and caps lock stop blinking but still black screen only. 1.2V power rail is present, CPU and GPU heat normally, RAM voltage present. I didn't test flash bios yet, but when there is water damage I mean this is not bios problem.. and on VGA external monitor also black screen only. Any idea? Thanks.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP G6-1270EC black screen
    In the Ram slot Test pin 30 75 199 203 supply any missing voltage on the coils ?
    • Techtiger
      • Oct 2014
      • 1602
      • france
      After test pin 13 34 EC supply
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        Thanks for answer.
        30 - 0V
        75 - 1.54V
        199 - 3.3V
        203 - 0.77V
        Where to measure pin 13 34 please?
        And on all coils are voltages only on charging coil is 0.6v
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Originally posted by DeniS182
          Thanks for answer.
          30 - 0V
          75 - 1.54V
          199 - 3.3V
          203 - 0.77V
          One of the most important single is missing now trace back pin 30 single to Q30 fet pin 1
          • DeniS182
            • Jun 2014
            • 328
            • Slovakia
            sorry, but I don't understand what you mean. PIN 1 of Q30 is GND.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Pin1 is Source CPU DRAMRST signal , what are the voltage on the Q30 pins & R374 both sides
              • DeniS182
                • Jun 2014
                • 328
                • Slovakia
                Q30 - PIN 3 - 5V
                PIN 2 - 0V
                PIN 1 -0V-GND
                I can't find R374 in schematic/boardview.
                We have right, same schematic?
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Q30 - PIN 3 - 5V
                  PIN 2 - 0V
                  PIN 1 -0V-GND
                  My mistake i was looking different Quant R check again Ram slot pin 198 126 1 for
                  pin 30 M_A_RST# comes from AMD MEMORY CHANNEL so if this voltage is missing no image fault
                  • DeniS182
                    • Jun 2014
                    • 328
                    • Slovakia
                    It's ok and I measured pins:
                    1 - 0.77V
                    126 - 0.77V
                    198 - 1.54V
                    30 - 0V
                    So if 30 - 0V my CPU/APU is the problem?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Often the failure point on this mb is circled. Check the requirement of these 2 IC and see if it helps.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        1 - 0.77V
                        126 - 0.77V
                        198 - 1.54V
                        30 - 0V
                        May or maynot be. DRAMRST# signal will not rise if apu/fch requirement are not fulfilled
                        • DeniS182
                          • Jun 2014
                          • 328
                          • Slovakia
                          this 2 IC's looks ok, output voltage is present.. hard to find the fault
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            so you get the out put voltage those 2 chips now check pin 14 SIO chip HWPG voltage is ok or not
                            • DeniS182
                              • Jun 2014
                              • 328
                              • Slovakia
                              14 pin sio 3.3v
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                what is the voltage on PL 22 is it 1.5V ? voltage on ram slot pin 116 120 200 202 ? do you try with another AMD CPU ?
                                • DeniS182
                                  • Jun 2014
                                  • 328
                                  • Slovakia
                                  PL22 - 1.1V
                                  116 - 1V
                                  120 - 0.89V
                                  200 - 3.3V
                                  202 - 3.3V
                                  And no because I found only am4400dec23hj (AMD A6-4400M) socket looks same but I mean it's not work. " 722-pin micro-PGA package. Please note that newer A-Series processors with Trinity and Richland cores fit into the socket FS1, but they won't work in it. "
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    I buy right CPU. Laptop works.
                                    Thanks all for help.
                                    • HTR-Informatique
                                      by HTR-Informatique
                                      02-09-2025, 06:51 AM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • VcemPzd
                                      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                      by VcemPzd
                                      Hello everyone !
                                      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                      04-28-2025, 10:14 AM
                                    • DaniK
                                      Acer Aspire E5-574-52RH - black screen
                                      by DaniK
                                      I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                      Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                      Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                      Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                      The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                      Symptoms are:
                                      - random black screen after displaying Acer logo...
                                      02-21-2024, 06:27 AM
                                    • turmix
                                      AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                      by turmix
                                      Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                      The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                      At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                      During another reassembly, I made a mistake, and...
                                      01-29-2024, 03:48 AM
