HP ZenBook 17 G4 not turning on
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have here this laptop. When dc adapter is connected, led near dc port is ON and after power button is pressed nothing happend. 19v is present, 5v is on power button. I found PL39 shorted to ground 0.5ohm. But i don't know what voltage is this rail. I desolder PJP2 jumper and tried inject 1V from my power supply to find something hot but my power supply after repair can supply only 0.7A when voltage is set to 1V. (Of course when I short probes its only 0.7A) and this current is too low to heat bad component and I dont't have thermal camera.
    Please have someone schematic or something what help me?
    Board is CPW70 LA-E171P Rev : 1.0
  • mon2
    • Dec 2019
    • 14162
    Re: HP ZenBook 17 G4 not turning on
    Remove all power. Meter in resistance mode (2k scale).
    Check resistance to ground for each coil on the board. You may have a faulty cap on the rail.
    Checking for a low resistance reading (for example a few hundred ohms is considered low for some of the higher voltage rails like 3v3 / 5v0).
    The CPU / GPU rails will be low voltage and low resistance is ok but post such findings.
    You can use alcohol instead of a thermal camera - we do this all the time. The alcohol will mist up from the heat due to the excessive current draw.
    Try not to inject voltage till more is known about the logic board as a bad short could kill the CPU / PCH (aka low voltage devices).
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Thanks for answer.
      I measured it like that, I found only this rail with too low resistance and I also mean this is cap or something in short. And I know CPU/PCH/GPU power rails are lower in ohms, but this is too low.ANd I use alcohol sometime but with low current which can I deliver with my bad power supply (0.7A) is hard to find spot where is hot.. I need to know what this rail is, which voltage I can inject here, my power supply works fine in higher voltage like 2-3V only, when I have here 1V it not work..
      • EdwardGeo
        • Mar 2020
        • 109
        • Ukraine
        Originally posted by DeniS182
        I have here this laptop. When dc adapter is connected, led near dc port is ON and after power button is pressed nothing happend. 19v is present, 5v is on power button. I found PL39 shorted to ground 0.5ohm. But i don’t know what voltage is this rail. I desolder PJP2 jumper and tried inject 1V from my power supply to find something hot but my power supply after repair can supply only 0.7A when voltage is set to 1V. (Of course when I short probes its only 0.7A) and this current is too low to heat bad component and I dont’t have thermal camera.
        look at images
        PL39 is 3.3V
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          Thank you for the pictures. Problem is in CHipset. I check the whole board, chipset is hot.
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
            ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
            This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
            09-07-2024, 06:31 AM
            by sam_sam_sam
            07-01-2024, 06:34 AM
