Asl50 la-c921p
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    Asl50 la-c921p
    Hi ,this board,don't boot up with 2 rams installed,boots fine with 1ram installed.
    Don't boot when other ram installed .Ram slot looks fine not lose,no pin bend,not Storting
    What could be causing problem
  • mon2
    • 14664
    Re: Asl50 la-c921p
    1) Both ram sticks are known to be good for this machine ? Install one stick - test it. Then remove the working stick and swap it with the other but use the same socket. Confirm both are working properly.
    Then repeat this test using only the next memory socket.
    2) Are the sticks of the same vendor / memory density ?
    3) You can check the voltage for the non-working memory socket to be sure the socket is being powered. Appears to be powered from +1v35.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 348
      • India
      Re: Asl50 la-c921p
      Yes both ram are working , tested on other set laptop.
      Yes both are same make,FSB , capacity, same too.
      I have to check power1v35,on both slot
      Just an update, after removing from defective slot ram ,even working slot also stops working/sensing no definite when and how it will start sensing again.
      • privato89
        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
        by privato89
        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
        Let's begin:
        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
        03-26-2024, 06:37 AM
      • Luke Anders
        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
        by Luke Anders
        A few details about the laptop itself:
        Name: Lenovo Legion 5
        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
        BIOS Version: GKCN60WW
        EC Version: GKEC65WW
        Serial Number: PF39AQ7Z
        Board Model: NM-D562 Rev 3.0
        RAM: 16GB Installed, DDR4 (brand new)
        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
        I bought this laptop recently from eBay as a faulty device....
        10-12-2024, 05:13 AM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • praveenramavath
        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
        by praveenramavath
        Hello All,
        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
        https://www.hifivision.com/threads/m...-screen.98243/
        Troubleshooting Summary: Majority Internet Radio - Flash Chip
        04-26-2025, 09:08 AM
