Help! Voltage injection not working
  • doncius85
    • Feb 2022
    • 10
    • DE
    Hello!
    Need help. Have two different dead laptop motherboards. One has a short on 3V rail, so I'm injecting voltage right there and it draws 8A, but nothing gets hot. Another board has a short on one of the mosfets. When injecting voltage, it draws 7A and the board is dead cold too. I'm inspecting using a thermal cam. What can be wrong? Where does those amps go? Since my power suply has a short circuit protection, for voltage injection I'm using Ni-MH battery, could this be a problem?
  • reformatt
    • Feb 2020
    • 1418
    Re: Help! Voltage injection not working
    Take the heatsink off the CPU and retest. Most shorts of this nature are the CPU/PCH
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8222
      if nothing is getting hot, the something is heatsinked pretty heavy...
      • petehall347
        • Jan 2015
        • 4427
        about 24w then 0.375 ohms . at 3v .
        • doncius85
          • Feb 2022
          • 10
          • DE
          Heat sinks removed, CPU's not getting warm on both boards. One board reads 0.1Ohm and another 0.2Ohm short. What's strange on the second board, that I'd say 30% of the mosfets reads 8Ohms Source to GND... Is that normal?
          • reformatt
            • Feb 2020
            • 1418
            I'd suggest getting something like the Mechanic TS-30A short killer in combination with a thermal camera. Voltage is selectable, and it will pulse on and off when a short is detected. So when a thermal camera is used, it makes the source of the short quite obvious without damaging the board in the process.
            Don't go above 1V when doing voltage injection. If you have a high side FET shorted in a buck converter for the PCH/CPU/GPU, any volts you inject will end up directly to said components.
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • NConstantinou
              19v rail short voltage injection help!
              by NConstantinou
              i HAVE AN HP MOBO WHICH HAS SHORT +VIN.
              THE SHORT APPEARS AFTER THER CURRENT SENSE RESISTOR.(REMOVED AND TESTED).
              I AM GETTING RESISTANCE TO GROUND 14 OHMS.
              I PLACED A JUMPER CABLE ON CURRENT SENSE RESISTOR AND I APPLIED 2V
              AND I INCREASE AMPS UPTO 0.86 SHOWNING CC ON PS FOR SHORT.
              I NOTICE PCH AEAR IS GETTING A LITTLE BIT WARM.
              I INCREASE AMPS TO 0.9 AND CC LIGHT ON PS WHEN OFF.
              ACCORDING TO PS SHORT CC LIGHT IS ON BETWEEN 0.27-0.86A
              WHY IS THIS!
              CAN SOMEONE EXPLAIN
              THANKS
              07-16-2022, 03:17 AM
            • survivalbloke
              Lenovo X280 - short on board, voltage injection pulling 4.9a but nothing heating up?
              by survivalbloke
              This laptop came in for no power. I saw the board was not taking any power so I pulled the board and began testing. As you see in the photo, on those pair of mosfets, I had 20v into and out of mosfet 1 and 20v into mosfet 2, but only 3v out of mosfet 2. I found a location which was shorted and injected 1v5a and it took all the current, but nothing is heating up with the thermal camera and I can't for the life of me figure out how 5a isn't showing on thermal.
              12-06-2023, 08:51 AM
            • abajor
              Asus G634j Rog Strix SCAR Power rail shorted nothing hot on thermal camera.
              by abajor
              I haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
              It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
              The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
              It draws 1.86A injecting directly to ground.
              Is this just the way it is when these ultra...
              03-19-2025, 03:23 AM
